Forum Gallery Shop Sponsors Directory
Home > Technical > Battery Charging
Reply to topic  Down to end
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
Battery Charging
I think I know the answer but just want to confirm...
With the ignition off is it possible to charge the battery via one of the 3 power outlets/cigarette lighter sockets, or do I need to direct connect to the battery terminal?. This with either a mains or solar powered charging device?
_________________
2008 WHITE TDV6
Post #170148 Tue May 20 2008 11:15am
Davel
England 2007 Range Rover Sport TDV6 HSE Java Black
I asked this the other day.
As the lighter socket is dead when the electrics are turned off and the key removed, you need to use a trickle charger, like Optimate etc, connected directly to the battery terminals.
I just connected mine up this morning.
Post #170169 Tue May 20 2008 12:57pm
View user's profile Send private message Reply with quote
Reply to topic  Back to top
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2005-2008 Martin Lewis
