![]() | Home > Europe > can the side step be fitted after market ? |
| ViewWise Joined: 13 Mar 2008 Location: London Posts: 106
Yes. Any dealership should be able to do it for you, or you can do it yourself (theres a land rover fitting guide floating around). Looked a bit complicated to me personally |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: Me fail English? That's unpossible. Posts: 17794
You can attempt it yourself, but as with a lot of these things it's easier to have someone else do it. |
| anthony-apl Joined: 07 Oct 2007 Location: sunny stockport Posts: 105
Do it yourself mate i did |
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 18003
I know member Umbertob takes his steps off when he goes off road so can't be that hard to fit if he dose it so often |
its a lot harder to fit them first though Jay as you have to fit the brackets underneath the car and change all the side moulding trims
| Supertrotter Joined: 10 Mar 2006 Location: Back in the warm bosom of Paphos Posts: 5858
I thought the LR steps are dealer fit anyway, even if you spec them from new? |
They are |
| boyd Joined: 29 Apr 2007 Location: at home Posts: 57
thinking is easy ...but getting these in europe, outside UK ...if you know where pls let me know |
Am I missing the point boyd, but can you not just get them mail ordered to you from wherever your nearest dealer is? |
| highbridgeflyer Joined: 06 Aug 2006 Location: Midlands Posts: 68
You can get the steps from any dealer. Easy to fit, and easy to take off. The RRS ones come with pre cut sill covers |
OEM LR side steps are easy to get at yr dealer for about 850 eur in Europe ,but for aftermarket ones you have to order them in the UK and postage is very expensive due to measurements,if they even want to send them to you.
Don't go aftermarket, go OE |
