Home > Technical > Adaptive Headlamps - identification |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
Nope - these are not adaptives.
Mon Mar 26 2007 8:40am |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
When you start the car with your headlamps on they will go left and right as well as up and down if you have the adaptive lamps PLUS you have a status / warning light that comes on when you first start the car. |
Mon Mar 26 2007 8:44am |
Adaptive Front Lighting System (AFS)
jHamshaw Member Since: 01 Mar 2007 Location: UK Posts: 37 |
So... you can have static bending lamps without full adaptives then??? Will look for dash warning light next time I go out, and make a note to drive in the dark again soon!! Cheers guys... |
Mon Mar 26 2007 11:49am |
sportman Member Since: 25 Jul 2005 Location: UAE Posts: 550 |
so if the swivelling headlamp unit is there u will notice the up and down movement during start up the engine right?
Mon Mar 26 2007 12:34pm |
Just checked - have got static bending, haven't got a dash light for adaptives - seems that one without the other is possible! Manual implies otherwise (as per quote above)..... |
Mon Mar 26 2007 1:44pm |
Try this ...
Tue Mar 27 2007 1:54am |
