| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Warnings in info screen |
| scorpio Joined: 08 Jul 2005 Location: London Posts: 142
tim, i had this message, but after playing around, i found that to raise from acces mode to regular mode i only have to touch switch once, i held it down,to long and car went into off road height |
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 7382
Scorpio, the RR I ran had a useful repeater switch with the lecky window switches for selecting access height! The Sport makes do without, but then it isn't a mountaineering expendition to get into the Sport even at Normal height! |
| Toodeep Joined: 09 Jul 2005 Posts: 42
Tim
| BN Joined: 10 Jul 2005 Location: Northamptonshire Posts: 58
These cars are so electrically intensive and sensitive that a battery voltage minimum of around 12.2 is set. Anything below that will cause all but the starter to either hybanate, go into low power mode or simply not work.
