Home > Technical > Tailgate
Page 3 of 4 <1234>
Despite not being affected back at the start of this thread, it seems mine has now fallen foul of this. Went to load up the back of mine yesterday, opened boot, turned around to pick something up, turned back and smack!! Rolling Eyes Maybe it is age thing... combined with the cold weather. I agree with Esoteric, while it's an understandable explanation it still shouldn't happen. Haven't had a car with a hatchback in years, so not sure if I remember other cars having their struts affected by the cold. Only aware of leaky struts up until now...
Post #7741 Mon Dec 12 2005 2:39pm
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
How can you spot a RRS driver - there the ones with bandages on their foreheads! RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #7744 Mon Dec 12 2005 3:14pm
RRUK
Noddy,
Had any response yet?
Anyone,
Has anyone reported this to their dealer, and if so, what was the reply?
Perhaps we should ask L322 owners on RR.net to see if they have the same problem, I shall set a post on fire over there and let you know what is said.
http://rangerovers.net/forum/viewtopic.php?t=4668
06MY FFRR Vogue TD6, JE Stage 1 Tune, Chrome Tubes, Full Privacy, Full Fat, Full On.
Post #7751 Mon Dec 12 2005 4:28pm
As well as this issue - does anyone else experience noise when going over speed bumps etc, I cant work out if its noise from tailgate or from the retractable loadspace cover?
Post #7854 Tue Dec 13 2005 1:54pm
What sort of noise? Like something is loose?
Post #7864 Tue Dec 13 2005 3:13pm
Hard to describe ( rattle ) - could be tailgate , but to make sure I will take out loadcover completely and go home via bumps to test.
Post #7870 Tue Dec 13 2005 3:39pm
Biggles
I have just this past morning heard a noise while going over speed bumps and rough roads. Sounds a s though it is coming from the front end though my first thoughts are to check the exhaust brackets and hangers on the ramps in our workshop.
Will report back to let you know the outcome. Its out there somewhere. Second V10 Treg on the drive at the moment.
Post #7874 Tue Dec 13 2005 3:45pm
RRUK
I have noticed some noises form under the car when going over slight bumps, mainly only hear it at low speeds, in and out the driveway etc, and I reckon its those damned lead weights under the car swinging about.
Post #7894 Tue Dec 13 2005 6:27pm
Left work last night & removed the rear loadspace cover. Went the usual route home ( via speed bumps around sons school ) and the noises/squeaks/rattle were still there Crying or Very sad So... verdict is ... its the tailgate. I would say its not adgusted correctly for a tight fit when shut. However not sure if its the main door/hatch or the glass top hatch ? Will get service to look at it when in for the recall.
Post #7910 Wed Dec 14 2005 10:35am
RRUK
Martin,
try unscrewing the rubber stops half a turn and then shutting the tailgate and trying that for a while.
Post #7911 Wed Dec 14 2005 10:52am
RRUK wrote:
Martin,
Will try this today.... cheers Smile
Post #7919 Wed Dec 14 2005 11:29am
I adjusted the rubbers on the glass hatch but still get noise Sad It is not possible to adjust the main boot door. Will need service to examine Confused
Post #7925 Wed Dec 14 2005 4:09pm
Jonny111s
I got this rattle too after I had the rear seats down. Rethreaded the rear seatbelts thru the wee brackets on the backrests and the noise has gone. I may have been lucky, but it's worth a try.
Post #7927 Wed Dec 14 2005 4:18pm
Cheers - but its not that ( already overcome that one ) its definately the tailgate
Post #7932 Wed Dec 14 2005 5:03pm
Jonny111s
Mm - . 'Looks l have a prpoper rattle to look forwrd to - it will remnd me of when I was a Mercedes owner!
Post #7934 Wed Dec 14 2005 5:10pm
Page 3 of 4 <1234>
