| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Off Topic > Help with Computers.. |
| kam100 Site Sponsor Joined: 28 Sep 2005 Location: In my office doing quotes!! Posts: 3997
As some of you may know (from previous posts).
All the 98 machines are network enabled with the relavant network cards plugged in, and working effectively (all can be seen on the network) but the XP machines although still connected to the network, cannot access the internet (happens a lot) even when reconfiguring the connection, sometimes it works, but for three of the PC's they are not working and are sitting there not being used now.
| LRtuning Joined: 26 Jul 2005 Location: London and Melbourne Posts: 403
Have you tried 'repairing' the XP computer network connections?
| kman Joined: 25 Nov 2005 Location: Bedfordshire, UK Posts: 19 |
dunno if this helps:
Make sure all computers 'automatically obtain IP address' and do the same for the DHCP server....if you dont it will cause a conflict as the XP machines will be 'barking up the wrong tree' |
Sending you a pm kam... |
thanks for all the tips TC..
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14724
or 20 apples..
In that case I suspect you have one main computer that is the 'allowed' to access the internet and all the other must 'share' the connection through the main computer.
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20048
Can the machines inside the router see themselves? i.e. can a machine that can't get to the internet see a machine on the other side of the room? Has there ever been a time where all the machines on your network could get to the internet simultaneously? Your router may only support a limited number of outbound connections.
Yep.. we access through the main computer downstairs.. it itself is the one with the main access, and the others are setup to access the internet through that computer.
