Home > Technical > Suspention squeek |
The doc Member Since: 31 Oct 2006 Posts: 1173 |
S E T F I R E to it |
Fri Jan 12 2007 5:58pm |
That's a really useful bit of help Doc!
Fri Jan 12 2007 6:02pm |
tomi.omni Member Since: 12 Jan 2007 Location: Dubai Posts: 3 |
Hi Doc,
Fri Jan 12 2007 6:26pm |
It will be burning if it doesn't start working |
Fri Jan 12 2007 7:32pm |
Huggy Bear Member Since: 28 Jan 2006 Location: Midlands Posts: 2 |
tomi - can often be the rear suspension joints that are in the rear knuckle that squeak (water can get in them and wash all the grease out). Worth a look if you ever take the wheel off - it is difficult to see them otherwise. The way I have found to check is to open the tailgate and jump up and down on the rear of the boot floor. If the suspension squeaks, then it is probably these. ===============================
Fri Jan 12 2007 10:29pm |
ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823 |
Unfortunately cannot afford an RRS(!), But I get to borrow my Boss's LR3 and RRS!
Fri Jan 12 2007 10:36pm |
TB Member Since: 19 Feb 2006 Location: Depends who wants to know . . . Posts: 5927 |
Especially if you jump up and down in the rear loadspace.
Fri Jan 12 2007 10:42pm |
homeins Member Since: 13 Jan 2007 Location: NORTH WEST LANCASHIRE Posts: 18 |
mine is to and it sounds like thhe engine is about to drop out like yours its a first addition model v8 all singing and dancing but why should it have this problem surrley tis is a re call ? |
Sun Jan 14 2007 3:23pm |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 |
its not a recall situation - recalls are for 'Safety Critical' issus |
Sun Jan 14 2007 4:20pm |
RRUK Member Since: 10 Jun 2005 Location: Leicestershire Posts: 2574 |
had my suspension bushes replaced at the front due to an inferior bushing used in early production models.
Sun Jan 21 2007 4:54pm |
