| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > General > SUSPENSION PROBLEM - SOUNDS LIKE A U/S SHOCK ABSORBER... |
| The doc Joined: 31 Oct 2006 Location: In a pond HYPNOTOAD Posts: 1086
homeins -
No way - I'm off to Gaydon area next week - shall I call in on you on the way to have a listen?
| ENVOY Joined: 09 Nov 2006 Location: staffordshire Posts: 5748
No they changed nothing, just stripped it then rebuilt it to the correct tourque settings.
DOC IS THE MAN |
| zulfi Joined: 23 Feb 2007 Location: leeds Posts: 2
i have a range rover sport 2006, with every extra you can think of, the machine cost me almost 60K. i took it in to the dealer, about the knocking sound i was getting from the front suspenion, they looked into it, and said they couldnt locate the probelm, and it may not be under warranty, as i a 22" alloys on it, and LR dont recomend that size for this car.
| the voice of reason Joined: 12 Dec 2006 Location: UK Posts: 16
Hi
Thanks VOR for that valued information, dont make it your last post as they are most welcome |
| Brian Mason Joined: 31 Aug 2006 Location: - - - - - - - - - - - - - Posts: 5303
Cheers VOR! Mine goes in for service and, hopefully, the same works as described to cure "knock." |
I would only add that LR have yet to produce any bulletins or info to dealers on this issue so don't expect your dealer to know this automatically, so far only dealers that have been actively involved with problem vehicles are likely to be aware, although LR technical should now be able to advise any dealers unsure of this update.
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 15501
VOR - Thank you very much. Good to see you back. WINNER - 2008 Outstanding Contribution
| All times are GMT |
