Home > General > SUSPENSION PROBLEM - SOUNDS LIKE A U/S SHOCK ABSORBER...
Page 13 of 15 <123 ... 12 131415>
The doc
homeins -
Thud Thud Thud Thud
Read the post above - from start pls!
Thud Thud Thud Thud
Then... book your car into HILLENDALE at NELSON - The Number is 01282 723723 - ask for Steve Marsden on service - he will sort it out - they sorted mine out 100%
Thud Thud Thud Thud
You have a PM
Thud Thud Thud Thud BMW 535d
Landcruiser VX 4.5
Post #75212 Mon Jan 15 2007 10:08am
ENVOY
Just got my motor back from the dealers, they have had it since Tuesday, they reckon they have stripped the front suspension down and then rebuilt it as per L/R instructions.
Guess what
Youve got it, its still knocking Crying or Very sad
Post #76823 Sat Jan 20 2007 7:58pm
The doc
No way - I'm off to Gaydon area next week - shall I call in on you on the way to have a listen?
Did they change the bushes that I had changed? Crying or Very sad BMW 535d
Landcruiser VX 4.5
Post #76838 Sat Jan 20 2007 11:09pm
ENVOY
No they changed nothing, just stripped it then rebuilt it to the correct tourque settings.
It might be me i, am not sure now weather or not it is my imagination, the guy from L/R said all the RRSs are the same, mines no different.
It dont mean its right though.
If your passing next week drop in for a coffee and a have a listen to my knock.
Drop me a pm doc
Post #76874 Sun Jan 21 2007 10:01am
The doc
The doc wrote:
Milestone Milestone Milestone Milestone Milestone Milestone Milestone Milestone
Ok sorry for the delay.
The parts changed on my car were:
2x Anti roll bar stirrup bushes
Part number RVU50011 @ £6 each!
Tell them to fit these asap BMW 535d
Landcruiser VX 4.5
Post #76994 Sun Jan 21 2007 11:18pm
ENVOY
DOC IS THE MAN Bow down Milestone Milestone Milestone Milestone Milestone Milestone Milestone Milestone at long last having given the dealers the part number that DOC has posted on here RVU50011, and with the aid of a new antiroll bar
NO MORE KNOCKING Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
its as quiet as a mouse(for now that is)
Post #86641 Fri Feb 23 2007 10:15am
The doc
Great news - I'm really happy for you - this seems to be on a roll!
If you knock - try the Doc Thumbs Up BMW 535d
Landcruiser VX 4.5
Post #86690 Fri Feb 23 2007 12:14pm
zulfi
2006 Range Rover Sport TDV6 HSE Java Black
Knocking Sound
i have a range rover sport 2006, with every extra you can think of, the machine cost me almost 60K. i took it in to the dealer, about the knocking sound i was getting from the front suspenion, they looked into it, and said they couldnt locate the probelm, and it may not be under warranty, as i a 22" alloys on it, and LR dont recomend that size for this car.
at that point i told him i have 2 of these vehicles, one is my wifes, with the std 19" alloys, and i have the same problem with that as well.
both vehicles went into LR in leeds, and were returned with the same problems.
this is disgusting from LR that they think they can get away with this, when i test drove this vehicle it was quiter than a mounse, now, every time i go over a amll bump, it feels like im in a fridge freezer with wheels.
if any one finds out what the problem is, please let me know asap, as my next step is to take this legal, if land lover do not get there head out of ther ASS.
Post #86695 Fri Feb 23 2007 12:53pm
ENVOY
Re: Knocking Sound
Ive just got mine sorted this week see the previous posts
Post #86699 Fri Feb 23 2007 1:22pm
The doc
Thud BMW 535d
Landcruiser VX 4.5
Post #86779 Fri Feb 23 2007 5:57pm
the voice of reason
Hi
I'm back for one more post
This issue has now been identified on customers vehicles via the EPQR system and customers vehicles have been inspected by LR engineering.
The result is that LR do now acknowledge that some vehicles can exhibit excessive ARC noise and have produced a fix which has been tried on several vehicles and proven to fix the issue in every case so far.
You will need to visit your local dealer whom by now should have "DVD 105 patch file 3" installed on their diagnostic systems, the new software contains a full update to the DSC system and now incorporates the addition of the vehicles steering angle sensor to the ARC system control sub system.
in rare cases the working of the system prior to this update may mean that the arc system bushes as mentioned here "RVU50011" may have some additional wear and replacement of these will remove any remaining excess system noise.
All customers whom have had this update and in some cases the bushes have since reported total happiness with noise levels.
It is also worth noting that those of you that have had the bushes already should seek this update immediately as it is likely the issue will return as your replacement bushes bed in.
Regards
VOR
Post #90510 Tue Mar 06 2007 9:17pm
ENVOY
Thanks VOR for that valued information, dont make it your last post as they are most welcome Thumbs Up
Post #90512 Tue Mar 06 2007 9:21pm
Brian Mason
Cheers VOR! Mine goes in for service and, hopefully, the same works as described to cure "knock." Thumbs Up Never Knowingly Offensive.., so P155 OFF!!!
_________________________________________
Post #90514 Tue Mar 06 2007 9:27pm
the voice of reason
I would only add that LR have yet to produce any bulletins or info to dealers on this issue so don't expect your dealer to know this automatically, so far only dealers that have been actively involved with problem vehicles are likely to be aware, although LR technical should now be able to advise any dealers unsure of this update.
VOR
PS ENVOY thanks for the vote of confidence my future posts depend largely on if I feel I'm falling on deaf ears?
Post #90517 Tue Mar 06 2007 9:34pm
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
VOR - Thank you very much. Good to see you back. WINNER - 2008 Outstanding Contribution
WINNER - 2008 ‘Just Doing What It’s Designed To Do’ Award
Runner Up - 2008 ‘Idler Of The Year’ Award
Post #90518 Tue Mar 06 2007 9:37pm
Copyright © 2005-2009 Martin Lewis
