| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Low Coolant Level |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: My arse, Your face. Posts: 20732
If the tank is actually full, then it sounds like the dealer has it right. I don't remember that ever being reported on here but that's not to say such a thing wouldn't happen |
| eskil Joined: 25 Dec 2006 Location: Norway Posts: 9
ok, it's soon going in 4 a service anyway, should be sorted then. Cheers! |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 15227
I had this - the float in the tank is absorbing water and sinks and sets off the low coolant warning. This is a warranty job and has happened to many. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1996
I have it for the past 3 weeks already.
| umbertob Joined: 22 Sep 2005 Location: Pasadena, CA Posts: 739
There is actually a TSB issued for this (see the NA version below, the one in Europe may or may not be different.) Problem is, for a while dealers in the US were replacing faulty expansion tanks with more faulty tanks! |
Thanks umbertob.
| MAW Joined: 06 May 2006 Location: Lincs Posts: 904
| Tim in Scotland Joined: 30 May 2005 Location: Driving along in my automobile Posts: 8082
Yep, had this after the dealer fitted the FBH which required draining the coolant down. I thought they hadn't fully refilled the reservoir and complained that they had had the car for 3 days and should have run it enough to find out if there were air locks. Turned out to be the sensor was faulty too. A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
| Lateral5 Joined: 07 Jun 2006 Location: Down south Posts: 293
Yep, mine has had that and is in at the moment getting it sorted. Also having some other minor work done.......namely the entire drivline being replaced |
| baxtermiller Joined: 15 Jan 2007 Location: Corona, Ca Posts: 2
I thought it was just me. Thanks for the responses. I will go stand in line for a back ordered part once again. :lol: |
Parts appear to be off backorder in UK now - booked in for Thursday... Also having OSR door seal replaced on pillar - adhesive drying out and peeled away... |
| All times are GMT |
Staying - Epsom Green Defender 90 for playing off road
