| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > SQUEAK FROM REAR BRAKES !! |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 15227
You might have run over Robin Sunpower! Seriously - it could be a small stone stuck in between something or your handbrake not fully disengaging. The weather might be a cause in some way. Not much use I'm afraid. |
| Martin Site Administrator & Owner Joined: 26 May 2005 Location: Shoreham-by-Sea Posts: 2249
Welcome to RRSPORT Big Bad Range |
| Bobby Joined: 07 Jun 2005 Location: Kuala Lumpur Posts: 1996
| RRUK Joined: 10 Jun 2005 Location: Certainly In-Vogue Posts: 2284
It is quite normal for such a large car's brakes to groan under slow manouvering, however if it is a high pitch squeal there could well be a piece of grit wedged in the caliper face, it will work itself out within a week's use. Now: Range Rover Vogue TD6, JE Stage 1. (Green!)
| BIG BAD RANGE Joined: 24 Nov 2005 Location: KENT Posts: 14
HI I TOOK THE RANGE BACK TO DEALER AND THEY STRIPPED THE REAR D/S CAILIPER AND GREASED IT ETC SEEMS OK AT THE MO.......... |
| umbertob Joined: 22 Sep 2005 Location: Pasadena, CA Posts: 739
BUT HE IS THE BIG BAD RANGE, DOGGONE IT!
Here is what my dealer did to stop the squeak on my brakes, according to the service invoice: "Checked and found excessive brake dust on calipers. Removed excess brake dust". The squeak is gone. |
as i stated before my squeak from the rear brakes/suspension did go but has now come back it comes and goes if you rock the car left to right and roll back on creep it is there sometimes...........any thoughts gents...... |
out of interest how many miles have you covered in the car? Now: Range Rover Vogue TD6, JE Stage 1. (Green!)
| All times are GMT |
