| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Tips & Tricks > road angel classic and RRS please help!! |
| JayMann Joined: 19 Jan 2006 Location: Growing old is mandatory; growing up is optional. Posts: 20901
I have the Road Angel Plus and it works fine in the middle of the RRS windscreen!
| kam100 Site Sponsor Joined: 28 Sep 2005 Location: In my office doing quotes!! Posts: 4185
mate you had any trouble with your road angel plus.. mine is dead.. battery issues.. and paulL's is dying too.. Gecko's was on when i drove his S4 to the last meet, but noticed his was plugged in too..
| Havank Joined: 20 Jun 2006 Location: West Sussex - UK Posts: 691 |
I also had lots of problems with the sat-nav in the van, has something to do with the sun-reflective windscreen, so needed an external antenna and all works fine
The night before last weeks meet i went to update my RA on the PC. I did have the software on it so downloaded that to get the lasted update. But first it did a new firmware update half way the screen went red and i thought it was dead!! so just left it the way it was and called RA them self. Tec support rang me back very quick (hour or so) He told me what to do and the end it was all normal! Think this may help with a few problems it has! RRS TDV6 Gone but still around
| welsh alex Joined: 15 Oct 2006 Location: england Posts: 17
thanks jaymann and havank,
Yes it's wired all i did was pop the trim off and push it back on but it may not be as easy as that in the RRS!
| simonsi Joined: 01 Dec 2006 Location: Leicester Posts: 206
simonsi,
| Brian Mason Joined: 31 Aug 2006 Location: - - - - - - - - - - - - - Posts: 5303
I have a Road Angel and it needs the Road Angel internal antenna which you fit to the the bottom right side of the screen where there's no heated screen element. No power required, plugs straight into the back of the unit and permanently sticks to the inside of screen, costs about £10, takes 5 mins to fit. Will not work, or not work as well, without it. Had same exactly problem with Mercedes SL and Freelander. When you change cars, take it with you. Good Luck! |
Apologies! Mine is indeed a New Road Angel, but I can fully appreciate your frustration as I can remember when I first encountered the problem and just couldn't figure out the reason. Good Luck! |
| All times are GMT |
