Home > Maintenance & Modifications > 19" Wheels - balancing weights in or out? |
Singletrack Member Since: 07 May 2006 Location: Belgium - Lasne Posts: 330 |
Just got the RRS back from the tyre place and I was disappointed to see that they had installed the balancing weights on the outside of the rim (clamped) as opposed to having them inside, held in place with adhesive as they are on the Stormers (and the Volvo).
Mon Nov 13 2006 4:11pm |
Thanks Tim - that pretty much jives with what the owner of the tyre shop told me. I just hate those clamped on weights...but it's just for wintertime anyway. 2006 Range Rover Sport TDV6 HSE, Java/Ebony/Cherry, Privacy, Sunroof, PTI, Premium Sound, SatNav, Cold Climate, Tow kit, CarStyle coded grill and vents, Tasmods, Stormers, JE Exhaust, Autobiography badge |
Mon Nov 13 2006 4:23pm |
umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944 |
Most of the 19" rims I have seen around here have the unsightly clamp-on weights, but my original OEMs came with stick-ons... I know they MUST now use stick-on balancing weights inside the rim to avoid possible chafing of the weights against the brake line (there was actually a recall issued for this a few months back, affecting all cars with 19" rims and non-Brembo brakes.) |
Mon Nov 13 2006 4:34pm |
d3matt Member Since: 11 Jul 2005 Location: Oxfordshire, UK Posts: 730 |
I also heard that they use clamp on weights as these don't come off when off-roading......but then I doubt if this is the reason. Matt
Mon Nov 13 2006 4:45pm |
From experience you get heaps of added balance weights when you offroad, comes in the form of mud and it can be a to get off from the inside of the rim without taking the wheels off! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Nov 13 2006 4:53pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
In my limited experience on this subject i thought the newer 19's had stick on weights and the older ones clamp on - in searching ebay I have seen both for sale but more without than with (I thought). Also wasn't there a bulletin related to weights and wheels and catching in the access mode or was this a diferent weight related issue (didn't pay that much attn).
Mon Nov 13 2006 5:08pm |
My 18"'s have stick on weights, but one of the rear ones has been replaced twice! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Nov 13 2006 5:43pm |
Found it! Thanks MAW and Umberto (twice in one day!)
Mon Nov 13 2006 6:27pm |
I thought I had posted this pdf a while back... Recall RB039 (basically the same Q&A posted by VA, plus technical instructions for the dealer):
Mon Nov 13 2006 11:10pm |
I hope there is no rim damage from the clip on weights. |
Tue Nov 14 2006 9:08am |
easauto Member Since: 20 Nov 2006 Location: MARYLAND Posts: 2 |
YOU MAY BALANCE YOUR TIRES ON THE INSIDE ONLY WITH TAPE ON WEIGHTS, OR YOU MAY BALANCE ON THE OUTSIDE WITH CLIP ON WEIGHTS. A LOT OF IT IS PREFERENCE AND LOOKS. I JUST RECENTLY REPLACED MY CONTIS WITH THE MICHELIN LATITUDES AT 30K AND USED TAPE ONS IN THE INSIDE AND THEY RIDE LIKE A DREAM. HOPE THAT HELPS. |
Mon Nov 20 2006 12:54am |
