Home > Maintenance & Modifications > Slight tapping from engine |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4779 |
Fri May 17 2019 4:46pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
You will need a c1 oil as below. Don't just put any oil in, incorrect oil can contribute to excess smoke.
Sat May 18 2019 8:49am |
with the gauge showing minimum (I guess it doesn't show any lower than that)
Sat May 18 2019 10:22am |
Crikey ! That's low
Sat May 18 2019 10:36am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
I think you are lucky you still have an engine.
Sat May 18 2019 3:06pm |
Keep driving around waiting for oil to turn up in the post
Sat May 18 2019 6:33pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Or don't drive it until he gets the correct grade Kev
Sat May 18 2019 8:20pm |
Opie do next day delivery. Get the bus or a taxi while waiting. No need to take the risk. |
Sun May 19 2019 10:51am |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 465 |
With the system telling you to add 1.5 litres you still have approx 4.4 litres in the engine,
Sun May 19 2019 1:20pm |
It would be interesting to know from the op what happens when 1.5l is added |
Sun May 19 2019 2:46pm |
Absolutely, the system only measures the top 1.5 litres so when it tells you to add that amount you may find it still tells you to add more. In fact you could be running almost dry and it would still tell you to add 1.5 litres.
Sun May 19 2019 4:39pm |
laurieandsar Member Since: 19 Sep 2018 Location: Yetminster Posts: 7 |
Hi all,
Fri May 24 2019 11:19am |
So, as said you were “off the bottom of the dip-stick.”
Fri May 24 2019 5:45pm |
The tapping I think is still there but not sure if it's in my mind now.
Fri May 24 2019 8:08pm |
