Home > In Car Electronics > Sat nav update advice |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
any nav updates will default the nav to begium, hence the UK postcodes not working....change search area to UK and all will be fine.. |
Mon May 13 2019 12:31pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
That wasnt the problem in my case it had corrupted the install , Mine was already set to GBR. |
Mon May 13 2019 12:41pm |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
I used a 32gb SanDisk ultra flair, 7 quid from Amazon, definitely need a min of 32, the update is 21.5gb. once updated I formatted the usb, now it is used for music. MY12 RRS HSE
Mon May 13 2019 4:50pm |
RJM16 Member Since: 11 Nov 2016 Location: Worcestershire Posts: 29 |
After 2 USB from Here car is in having firmware updated, and then they have the care on life support battery over weekend to see if update will load, as after 1.5 hours still showing zero percent.
Fri May 17 2019 6:13pm |
possible worthwhile upgrade
Thu May 30 2019 8:51am |
