Home > General > Suspension issue with codes. Electrical or compressor? |
u codes are lost comms and can be ignores normally but check wireing connecters where they rub under arches and the like search on here and sister site disco 3 there are a few thread's about wires chaffing in and around the wheel arch |
Thu Apr 25 2019 6:49pm |
Silverman Member Since: 25 Apr 2019 Location: London Posts: 30 |
Thanks. I’ll take a look under the car tomorrow.
Thu Apr 25 2019 7:09pm |
i have heard of problems front nearside and offside rear try the rear first as there's no cover there but someone will come along with more idea's and knowledge |
Thu Apr 25 2019 7:13pm |
Cheers. Yeah hopefully someone will give me some pointers who’s had the same problem. I done a search but couldn’t find anything relevant.
Thu Apr 25 2019 7:52pm |
Anyone? Some help would really be appreciated
Fri Apr 26 2019 3:02pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8840 |
The problem is that the codes are incomplete. Presumably a generic reader was used. There are three entries for C1A27, 3 entries for U0132. By the way, you can download a free copy of the workshop manual which is invaluable. Search for a member on here called naks. There a link in his signature block to a download.
Fri Apr 26 2019 3:40pm |
Thanks for that. My scanner is The Icarsoft 930 for Land Rover. It’s under £100 so I guess you get what you pay for.
Fri Apr 26 2019 5:33pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
If you remove the relay you can bridge the 2 large contacts and see if the Comp runs.
Fri Apr 26 2019 6:18pm |
Thanks Andy
Fri Apr 26 2019 7:22pm |
May as well power compressor directly on the thick wires.
Fri Apr 26 2019 8:03pm |
Thanks Andy. I’ll try and get that tested tomorrow and report back.
Fri Apr 26 2019 8:20pm |
I just watched this vid.
Fri Apr 26 2019 8:54pm |
Same place.
Fri Apr 26 2019 9:12pm |
Don’t use the factory jack on these. They are very dangerous. |
Fri Apr 26 2019 9:22pm |
