Home > Technical > Suspension issue |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 916 |
Your right,, the compressor is located by the rear nearside passenger door. I wouldn't have thought the system would be throwing out rusty water as it has its own filter dryer on the end of the compressor but their is still a good chance you have a leak. I would go armed with some soapy water in a spray bottle and work along the pipes as best you can to see if you can spot any leaks. Some of the early compressors suffered from cracked end plates but you will have to remove the cover from the bottom of the compressor to get a look at it. Other than that the valve blocks sometimes stick causing issues, this is located on the rear axle I think,, it can be cleaned and serviced if your handy with spanner or two. 2010 RRS, TDV8
Mon Apr 08 2019 5:25am |
M9G UK Member Since: 02 Feb 2019 Location: Somerset Posts: 160 |
OK thanks, somewhere too start. Thinking about it over night something sticky sounds feasible as I have this morning noticed that over night the corner hasn't dropped and is still at the same height as the other side so would almost like to rule out a leak as would think the one side would drop if there was a leak? 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Mon Apr 08 2019 5:56am |
Sounds logical,, if you had a leak on one corner it would always drop at that side I think. 2010 RRS, TDV8
Mon Apr 08 2019 6:27am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4755 |
They self level when parked (drop down).
Mon Apr 08 2019 11:05am |
ah right ok i'll try that, Is it fuse number 3? 5 amp?
Mon Apr 08 2019 3:26pm |
It is a small 20A yellow fuse under the bonnet |
Mon Apr 08 2019 5:14pm |
Mon Apr 08 2019 5:22pm |
Fuse 26 then. I did do a search on here and saw a suspension issue and the guy removed fuse number 3 which was a 5amp so thought it was that one.
Mon Apr 08 2019 5:27pm |
You ensure the car is at a decent high height, i.e it has recently been driven.
Mon Apr 08 2019 5:31pm |
Cool thanks yep number 26
Mon Apr 08 2019 6:06pm |
OK so following morning, although a slight difference to begin with last night and the removal of fuse 26 this morning there is no difference in the heights, both exactly the same so guessing no leaks.
Tue Apr 09 2019 5:54am |
either you removed the wrong fuse
Tue Apr 09 2019 11:07am |
It was in the normal drive mode when I parked up and the fuse was the 20amp yellow one as in your picture 2008 RRS 2.7TD in Stornoway grey, black leather and 22 inch alloys
Tue Apr 09 2019 2:59pm |
Ok so im trying this again. I have had the engine running and have put the suspension right to the top then right to the bottom then back into the driving height, removed fuse 26 and I also removed fuse 3 which has the same logo as the 26 and ive now left it.
Tue Apr 09 2019 7:12pm |
