Home > Faults & Fixes > Fault code P0234
Tyrefitter
Fault code P0234
Started car up yesterday & engine management light came on,I plugged my diagnostics machine & the code came up with Turbo/Supercharger over boost condition,,car was running fine so I cleared the code,,should I call LR assist & explain what happened or just leave it as the car is running fine. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #578546 Sun Apr 07 2019 9:04am
Wilco
Just had same code come up and like you engine seems to be running fine.
Did you get it checked or has it happened since?
Thanks
Post #613911 Sat May 22 2021 5:07pm
Tyrefitter
Sold car last year,,later on after that happened I had problem with throttle body sticking,you could try some throttle body cleaner on the flap inside to help it,mine in the end went into Lr & had new throttle body fitted under warranty. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #613912 Sat May 22 2021 5:44pm
Wilco
Thanks, I found the thread about it and your photo of throttle body clip. So just removed mine and flap was a bit sticky so freed it and just off to Halfords to get some cleaner to spray on.
Post #613913 Sat May 22 2021 5:50pm
Tyrefitter
Make sure it’s throttle body cleaner,,you don’t want anything going in the inlet to f@@k it up. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #613914 Sat May 22 2021 5:52pm
Wilco
Post #613915 Sat May 22 2021 5:52pm
Scootrover
Hi all, I am hoping you can help or share your wisdom!
I picked up my new to me RRS 2017 sdv6 2 days ago and today driving to work noticed the engine management light on. Called RAC who plugged it in and showed a reading 3 readings of P0234 ( turbo charger engine boost conditioner exceeded )
The car drove as normal and would not have know should I have not noticed the light.
The RAC reset it and said to see if it comes back on.
First question is will the fault re-appear in the form of the EM light now it has been reset…. If a problem exists?
I drove it home tonight for 12 plus miles since it has been reset and no issues.
2nd point / question - the previous owner did very few miles Over the past 6 months and I drove 100miles to get the car home. Could this have any bearing on this code being activated in terms of giving it a long run down the motorway?
The car has full LRSH and was serviced only a few thousand mikes ago. Not a great start and feel I will just be paranoid waiting for the light to deactivate Sad
Any advice / shared experience greatly appreciated.
Post #617745 Mon Sep 27 2021 9:50pm
Tyrefitter
Throttle body sticking,I had same problem & LR fitted new throttle body under warranty.You could pull the pipe off the throttle body & spray with throttle body cleaner as it will free it off but don’t know for how long.Put a screwdriver under the metal clip pictured & pull it up then pull pipe off.
 Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #617749 Tue Sep 28 2021 5:46am
Scootrover
Thanks for the update, the light came back on today during a very steady drive home 😩
It’s booked into an independent LR garage tomorrow so fingers crossed will get it sorted. Not filled me full of confidence for a car Iv had for 3 days!
Thanks again.
Post #617758 Tue Sep 28 2021 5:17pm
Andrei
Romania 2013 Range Rover Sport 3.0 TDV6 HSE Java Black
How did you solved the issue . I have the same thing with the overboost and dpf not regenrating . I ve change the throttle body and the map sensor and the overboost came back ! Please help i just bought the car and i dont know what else to do !
Post #639370 Sun Feb 04 2024 6:43pm
