Home > Technical > suspension and AFS |
Skankmonkey Member Since: 22 Dec 2018 Location: Gloucestershire Posts: 12 |
Well, looks like I foxed people by the lack of answers but yes it massively affects the afs system. Just so people know👍🏻😬 If at first you don't succeed...….. forget it!!! |
Sat Mar 30 2019 11:17am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Yes it would, they are linked. Even a bad bulb can cause issues. 2012 5.0 SC AB
Sun Mar 31 2019 10:41pm |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1532 |
I would expect that suspension problems would affect the AFS system as the reason for the "dance" is to check that the direction of the headlight beam is not dazzling oncoming traffic. However, this doesn't necessarily mean that the issue is only with the suspension. The AFS system is notoriously finicky and should be suspect in its own right. Having said that if both lights are pointing down I would think it unlikely to be the AFS system as I haven't heard of both going wrong a the same time.
Tue Apr 02 2019 7:35am |
