Home > Faults & Fixes > Charging system fault |
hh Member Since: 09 May 2015 Location: Stirlingshire Posts: 23 |
Hi All,
Mon Mar 25 2019 6:56pm |
Have you checked all belts and connections? Had any work done recently? 2012 5.0 SC AB
Mon Mar 25 2019 7:55pm |
Hi Gogsy1956. It was the most obvious for normal cars wasn’t sure about the sport I will get it changed asap.
Mon Mar 25 2019 8:40pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8843 |
If the battery has got that low then you'll need a new battery too. 2012 SDV6 - it's missing a couple of cylinders
Mon Mar 25 2019 10:40pm |
Thanks RRSTDV8 I was hoping to get away with the battery but it makes sense to replace the battery as well.
Tue Mar 26 2019 11:23am |
