Home > Technical > scraping noise coming from new brakes
f11rfn
Hi chaps
need some help, my range rover sport 2005 tdv6 was shaking alot around 40mph onwards, i had balancing done with no resolve, so i had the front brakes checked and the garage said they were knackered, so i had new brake pads and discs fitted, the shake was till there and it started to make a scraping noise aswell now, more louder on lower speeds, you can hear it was coming from the wheels, also noticed brake pedal was soft they said will harden after bedding in the brakes. After checking the drivers side hub had play, so i had that changed, the steering shake has redunced alot but the grindin noise is still there and has slight steering shake aswell. I also had brand new calipers fitted so they cannot be sticking. Also the front tyres are new, any help as this noise is very annoying and something is scrapping, garage had look said they cannot see anything?? Big Cry
Post #576930 Wed Mar 13 2019 10:58am
MGO
Ireland 2012 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
what garage was it?
indie or some general jokers?
soft brake pedal is not something that will fix itself
vibration issue... have you checked the suspension bushes? outer ball joint on upper and lower arms? what about wheel bearings?
the grinding noise could be wheel bearings. or the drive shaft UJs 2007 TDV6 RRS HSE..now gone
2012 3.0 SDV6 RRS HSE
Post #576936 Wed Mar 13 2019 11:30am
f11rfn
its a independant garage, been using them for quite long time, the scraping noise was not there before i changed the brakes, its appeared after, had mot 2 months ago no advisories on anything, and both bearings have been changed, but the pedal is still soft, is it possible the pads have not been inserted correctley? as after a short drive the discs are very hot or is this normal?
thanks
Post #576937 Wed Mar 13 2019 11:38am
PC76
Sounds like you may have a couple of issues.
Is the steering wobble when breaking or just driving straight? if when breaking then the discs have warped. if driving straight then first suspect would be incorrect wheel balance, this tends to show at a set speed and can reduce the faster you go.
Check for play in your bearings, if they have used a cheap set it is not unknown for them to have play from new.
Check the rear protection plate and make sure it's not been deformed and now rubbing against the disc. check for stones trapped between disc and pads
Soft brake peddle is air in the lines, replace brake fluid ensuring proper bleeding
Check if caliper is moving freely i have had the slide bolts stick and cause the disc to warp.
all of the above you can do yourself with no or little help from anyone if you are confident.
what area are you in, other members could recommend a reputable independent who would give you knowledgeable and trustworthy advice.
Post #576942 Wed Mar 13 2019 1:27pm
DrRob
That garage is to be avoided Rolling Eyes Visitor from fullfatrr.com
* Current: 2011 4.4 TDV8 Full Fat. Amazing piece of kit.
Post #576955 Wed Mar 13 2019 5:40pm
DrRob
Where are you located? We can collectively recommend somewhere. Your profile is too generic Whistle Visitor from fullfatrr.com
Post #576956 Wed Mar 13 2019 5:41pm
f11rfn
it has slight wobble in straight not braking, had the balancing done aswell, only had front brakes done and we checked if the brake cover is hitting but its clear, also it only started making this noise after the brakes were chnaged, the calipers are new, if the brakes are not bled properley could this cause the caliper to stick?
Post #576958 Wed Mar 13 2019 6:18pm
f11rfn
im based in birmingham Smile
Post #576959 Wed Mar 13 2019 6:19pm
DrRob
Sorry, don’t know anyone there....
Alltrack4x4 in Malvern are good Visitor from fullfatrr.com
Post #576963 Wed Mar 13 2019 8:05pm
f11rfn
ok thanks
Post #576969 Wed Mar 13 2019 11:51pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
ATL in Dudley which is just up the road from you.
Post #576972 Thu Mar 14 2019 8:10am
Brit Plumber
After you’ve driven a while, splash some water on your discs to see if they hiss. I reckon the pistons are corroded or dirty. When pads are changed the material is much thicker and the previously exposed section of piston now need to slide in and out of the caliper. They can come out ok under brake pressure but don’t go in as well as there’s no pressure to withdraw them. My opinion is you need a caliper and piston clean up and possibly an overhaul. As for the wobble, do you have a light chattering through the wheel when driving slow over a reasonably uneven road? 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #576989 Thu Mar 14 2019 11:42am
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
I think Brit got it right. look at your calipter pistons and leaking rubbers RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #576992 Thu Mar 14 2019 11:53am
If I'm reading the original post correctly the OP has already had new callipers fitted and the fault is still there, but I could be wrong, could the guide pins/slide be partially siezed causing caliper to stick if that is the cause of the noise.
Post #576997 Thu Mar 14 2019 12:33pm
Brit Plumber
Deleted my reply as Col has said, I missed the last part of the OPs message stating the callipers had been replaced.
I’d still check for the discs getting hot as a collapsed brake pipe can cause similar issues. A reduced pipe bore will restrict the return of fluid. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #576998 Thu Mar 14 2019 1:15pm
