Home > General > Glovebox Light
Ady 555 wrote:
Rolling with laughter Is that avatar your new mode of transport that you've bought for woodie Question Laughing
New mode of transport Thumbs Up
.......bought for woodie Question Shocked Question ON THE WAY: BMW F21 M140i
Post #363264 Thu Nov 15 2012 3:49pm
mse
i thought he was band for a bit after the incident?? Rolling with laughter Mike
2014 Facelift Discovery
Post #363275 Thu Nov 15 2012 4:06pm
Yes he was sent on his bike Laughing Thumbs Up
Post #363276 Thu Nov 15 2012 4:08pm
Ah, you meant Wiggo Laughing ON THE WAY: BMW F21 M140i
Post #363279 Thu Nov 15 2012 4:09pm
Ah yes, thats him. Laughing
Post #363280 Thu Nov 15 2012 4:10pm
mse
Set up and well executed! Mike
Post #363281 Thu Nov 15 2012 4:10pm
panda
Just put led's in all the lights. your bit on the glove box was perfect thanks larsh Thumbs Up Thumbs Up
Just got to sort out the H11 fogs then all done
Post #364378 Sun Nov 25 2012 4:12pm
Kenzi
Australia
I know I'm reviving an old topic here but does anyone have links to an LED for the glove box? Needs to fit a 2010 RRS facelift.
My one doesn't work so I need to replace it.
Post #397301 Sat Oct 05 2013 4:09pm
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Great photos and instructions Larsh!
Many thanks for posting.
This is the final bulb I needed to replace with an LED and wondered how to gain access to it.
Great work.
Gaz.
Post #400878 Sat Nov 02 2013 12:46pm
JPR 1
JLR one would of probably set on fire. Current Volvo XC90 R Design T8
Gone 2010 TDV8. Stornoway Grey
Gone VW R50, AUDI S8, ML320 Sport, FFRR V8
Stolen 2007 TDV8.
Post #400882 Sat Nov 02 2013 2:35pm
itsmeagain
larsh wrote:
The topic is a bit old, but maybe someone are interested in a top up with some pictures.
If the lamp is broken, why not replace it with a 5-LED wedge lamp, like this one:
This LED will draw 0.75W instead of the original 5W, and does not get hot.
As mentioned in the discussion, the glovebox lamp is very well hidden:
Instead of trying to get the bulb out from the nearly invisible socket, the whole socket can be taken out.
Use a small screwdriver or plier to loosen it from the panel. Your child's small fingers might be helpful to get hold of the loose socket from behind the panel:
Cable & plug is still attached to the socket. To get it off, use a plier to press in the plug's locking tab while pulling the cable:
The LED replacement does not reach the bottom of the socket, unless you cut off the small tabs supporting the original bulb:
Now it's all the way in:
Plug the cable back in the socket. Check that the rest of the interior lamps are on. If no light from the LED, take it out of the socket, turn it 180 degrees and put it back.
Now, try to get the assembly back in place (your child's small fingers again).
After this, replacing the rest of the interior lamps is a piece of cake Wink
Just fitted mine, the bulb holder fell apart as i tried to get the bulb in. Any ideas jow much a new one is? Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
2008 Seat Leon K1
2012 Audi A1 2.0litre Black Edition TDI
2004 Audi A4 convertible
2004 Audi A2 TDI
Post #435507 Sat Sep 06 2014 10:18pm
Blueskye1
Wales 2008 Range Rover Sport TDV6 HSE Java Black
Thanks to the memory banks Thumbs Up
Managed to find & replace blown glove box bulb.
As mentioned in previous posts & after a fiddle be careful not to damage the push lugs on switch otherwise when you shut the glove box it will push out the plunger switch Question
Word of warning I replaced with a spare original bulb & it gets Censored hot
Andrew Very Happy My first RRS HSE Purchased June 2016
Java Black 2.7
Date of first registration 22 February 2008
Cousin of the King of Stamford Bridge R.I.P. Ossie
Post #510187 Wed Nov 16 2016 4:01pm
patski
United States
Thanks! Even my fat fingers managed it.
Post #575417 Sun Feb 17 2019 1:57am
