Home > Faults & Fixes > Suspension fault. Normal height only |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 118 |
Mine 'went' a couple of months ago and I was told it's 60mph where the car lowers and that makes a bit of sense in that every time I got to 60, the message came up reminding me to stay at 30!! In my case, the reason was nothing more than a frayed wire - couple of bob at the Indie - sorted. |
Mon Dec 03 2018 3:14pm |
Plazmapete Member Since: 05 Jun 2016 Location: Cannock Posts: 118 |
Depends what compressor you have. The Hitachi or Dunlop one is around £300. The AMK can be from £400 to £600 depending on where you get it. It's only an hour tops to fit new one. My fault is actually a leaking air resavoir which is being replaced tomorrow. Hopefully it's all sorted then. New alternator.
Mon Dec 03 2018 7:23pm |
Mon Dec 03 2018 7:37pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1240 |
Well my Normal Height only stayed on, so it went into my indie yesterday and they have confirmed it needs a new compressor. They’re fitting a Hitachi one on Monday and fitting EGR blanks. The car only has 60k on it but is 12 years old.
Sat Dec 08 2018 8:44am |
Well after fitting the AMK compressor it's
Sun Dec 16 2018 9:52am |
Pinnacle Member Since: 13 Mar 2018 Location: Romford Posts: 72 |
Had this on mine for a few days, then when I went to start it one morning. I started to get gear box fault errors, this error, that error, not in park error etc.
Mon Feb 04 2019 2:03pm |
derekmines Member Since: 22 Apr 2019 Location: MELKSHAM Posts: 133 |
Mine's gone all of sudden overnight.
Wed Jul 03 2019 4:06pm |
C1A20 and C1A13 fault codes on mine today, Internet research not much help on this problem as there are so many possible causes to every symptom.
Thu Jul 04 2019 10:04am |
Eskimo Member Since: 21 Oct 2018 Location: Worcestershire Posts: 72 |
If it helps, I had the same fault codes on mine and the fix was a new Dunlop compressor from MM 4x4.
Thu Jul 04 2019 1:49pm |
Yep, local Landie specialist says new compressor time for me as well... in addition as the bracket holding the current AMK compressor is snapped I might as well upgrade to the newer type unit.... more $$ but a better quality product and longer term fix apparently. |
Fri Jul 05 2019 11:10am |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 |
Have a read on the Disco4 sister forum about compressors amd quality. There's a host of threads about rebuilds and air dryer service replacement etc.
Sat Jul 06 2019 6:02am |
So 2 weeks into the new compressor and issues again - same suspension failure orange triangle, joined tonight by a red triangle suspension failure max 30mph drive.
Thu Aug 01 2019 6:37pm |
ShooterNeil Member Since: 14 Nov 2012 Location: Tamworth Posts: 422 |
Who’s looking at it for you 61 AB 5.0 supercharged rocket
Thu Aug 01 2019 10:51pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
What compressor did they fit and what codes are they getting? Kev
Fri Aug 02 2019 6:54am |
