Home > Technical > IID Tool - what settings did you add/change? |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 |
Timed climate & Remote park heat |
Mon Jan 14 2019 7:24pm |
Buster007 Member Since: 02 Dec 2010 Location: Essex Posts: 649 |
Mon Jan 14 2019 7:52pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
Only a couple of settings for drl's and they only work in conjuntion with dipped headlights
Mon Jan 14 2019 7:57pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
As Col said, I played with the DRL settings and you only get the normal lights on. Which if you actually have the proper Dealer fit DRLs will stop them working lol. 2012 5.0 SC AB
Mon Jan 14 2019 8:13pm |
So no setting for just sidelights (the LED's) to come on when the engine is running? I'll still have to turn them on myself with the switch - how disappointing....
Mon Jan 14 2019 8:27pm |
micknolan Member Since: 19 Apr 2017 Location: West Midlands Posts: 39 |
Might be of help.
Mon Jan 14 2019 8:44pm |
Think I found it:
Mon Jan 14 2019 8:52pm |
Posted this 3-4 years ago about what you can actualy get with the DRL's in the CCF files.
Mon Jan 14 2019 8:55pm |
They may have come down a bit?
Mon Jan 14 2019 9:04pm |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
I enabled puddle lights in the mirrors after fitting new mirrors 2016 Black SDV8 Autobiography
Mon Jan 14 2019 9:30pm |
Sounds good Stephen - where did you get the puddle lights? Any pictures? Cheers Laurence. |
Mon Jan 14 2019 9:36pm |
I haven't managed to get pics yet but I bought them from eBay (needed the mirror body and the light housing)
Mon Jan 14 2019 9:42pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I did the following mod on mine so that the LEDs within the headlight units are on whenever the ignition is on (or when the car is 'awake').
Mon Jan 14 2019 11:31pm |
Now I am not a auto electrician and not going to pretend to be one, but would this not work. As pin 2 in the headlamp plug is the sidelight, and if you have AFS lights then pin 14 is a ignition live, disconnect pin 2 wire from the plug and take a feed from pin 14 to pin 2 position in the plug, "not the wire you disconnected" that would then give a live feed to the sidelight to put them on as soon as ignition is turned on. If you then connect a small bulb holder with something like a 5w bulb in it to the wire you removed from position 2 on the headlight plug, this would then illuminate as soon as you put the actual lights on to stop and faults appearing, you could always tuck the holder out of site somewhere under the bonnet so it doesn't show. The only issue I can see is if you put the sidelights on without ignition you will not have front sidelights, unless of course you can use a diodes in the circuit somehow to prevent a back feed when ignition turned on and actualy reconnect the sidelight wire back to pin2. As I said not a auto electrician so probably talking complete and utter rubbish.
Tue Jan 15 2019 12:26am |
