Home > General > Cannot seem to find the cause
Sham91
United Kingdom 2010 Range Rover Sport 3.0 TDV6 Autobiography Bonatti Grey
Literally cannot seem to find the cause of this and it’s driving me insane.
While this has been going on I’ve had lower suspension arms changed, bushes changed, suspension compressor changed erm few other things but cannot think right now lol
So basically going over any kind of bump over 20-30mph the back boot area is noisy but I have nothing there, the car is literally empty when I drive to work and back these days.
Has anyone come across this before? RRS TDV6 2010 Smile
Post #570777 Sun Dec 09 2018 7:47pm
Stevepd
From memory I think the rear exhaust has been mentioned before. Perhaps just give that a once over.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #570787 Sun Dec 09 2018 9:15pm
Brit Plumber
Or possibly the harmonic?? weights under the car swinging 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #570789 Sun Dec 09 2018 9:18pm
Sham91
Harmonics? is this normal lol
I'll get the exhaust looked at but recetly had new tips fitted and the noise was there before that too, im sure the guys would have mentioned if the exhaust was loose RRS TDV6 2010 Smile
Post #570826 Mon Dec 10 2018 2:33pm
Lindab
Try some heavy weights in the boot. (bags of sand) & see if noise is still there or set to off road height & see if its there. May point to suspension air bags. Just a guess.
Post #570827 Mon Dec 10 2018 2:43pm
Brit Plumber
There’s 2 very heavy swinging weight at the rear to (I believe) dampen harmonic resonance in the body. These weights can knock as they swing. Someone with a better idea can explain. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #570828 Mon Dec 10 2018 3:17pm
Tim in Scotland
If you have added any aftermarket exhaust or exhaust trims these can tap on the harmonic balance weights and the mountings, when I added chrome tail pipe trims to my TDV8 in 2007 it took an age to find that that was the cause of the metallic rattle from the near side rear. Loosened off the trim and turned it a tiny bit to clear the harmonic damper and no more rattles. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #570832 Mon Dec 10 2018 4:08pm
Sham91
Thank for all your input, I'll bear it all in mind when I take it to Land Rover specialist after I've tested it in off road height.
Will see how it goes and report back Smile RRS TDV6 2010 Smile
Post #570835 Mon Dec 10 2018 5:25pm
Sham91
tried off road and the noise is still there, could that mean the airbags ? RRS TDV6 2010 Smile
Post #570886 Tue Dec 11 2018 10:08am
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
I had something similar which was worse going slowly over a rough road than potholes. I had my local indy look at the bushes and they said all was well, ie it would pass an MOT. However there was a small amount of movement in the rear ARB bushes. I had them replaced (£250) and all is now quiet.
Post #570913 Tue Dec 11 2018 2:24pm
Sham91
Rear arc bar was found leaking at service 3 weeks ago and had it replaced under warranty £2850 job but noise still there over humps and potholes lol RRS TDV6 2010 Smile
Post #570914 Tue Dec 11 2018 3:43pm
Bardley
Spare wheel?
Is your spare wheel tight or moving with a thump on the underside?
Anything in any side carrying areas? (not sure what you have on a RR..) 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #570915 Tue Dec 11 2018 3:57pm
Sham91
Only stuff in the rear area is the break down kit but that's well fitted..
Good shout on the spare wheel though, could be something simple as that lol....I'll get it checked Smile RRS TDV6 2010 Smile
Post #570916 Tue Dec 11 2018 4:58pm
