Home > General > Mirror/Door Puddle Lights Logic |
TubaPlayer Member Since: 27 Nov 2015 Location: Rochdale Posts: 189 |
I have noticed that the puddle lights on my 2013 Black Edition Seem to have some sort of logic!
Sat Dec 08 2018 5:48pm |
If unlocking all interior lights (except the two front bottom door ones) work as expected (come on when door is opened) and the mirrors light up. Then when you open the doors next time all lights work as expected except the mirrors don't come on. 2016 Black SDV8 Autobiography
Sat Dec 08 2018 8:29pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4829 |
That's how mine work, puddle lights in mirrors only work when unlocking the car. All other times just interior and door ones.
Sat Dec 08 2018 9:29pm |
Thanks Col,
Sat Dec 08 2018 9:47pm |
Sat Dec 08 2018 9:53pm |
Thanks Col,
Sat Dec 08 2018 10:03pm |
About a sixty second delay fof the mirror light to go out first unless ignition turned on.
Sat Dec 08 2018 10:09pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Mine are the same and factory fit. I assume mirror come on when you unlock the car and therefor don’t need the door ones as you can see the ground as you approach. Then when you exit the vehicle the mirror ones are of no use so the door lights come on instead, illuminating the ground as you open the door. As there are no mirror lights on the rear the door lights always come on. It had we confused when I first got the car. 2012 5.0 SC AB
Sat Dec 08 2018 11:45pm |
