Home > General > Squeaky front seats |
michaelsanderson Member Since: 14 Dec 2014 Location: West Yorkshire Posts: 32 |
Mine did exactly this. It was intermittent but when it was doing it, seat position didn't matter.
Fri Aug 07 2015 9:58pm |
nicka113 Member Since: 16 Jan 2012 Location: Essex Posts: 20 |
The trim panels just pop off and the seat is held in by 5 star nuts, the bottom bolster is held by 4 star nuts directly in the bottom of it...
Sat Aug 08 2015 12:43am |
AlanEricThompson Member Since: 14 Oct 2013 Location: Nuneaton Posts: 96 |
Not sure if it's a fixing or not, it feels like a squeaky spring, are there springs in the seats? 3.0 HSE RRS Stornaway (current)
Sat Aug 08 2015 10:21am |
The bottom is just foam on an aluminium type shaper base so no there no springs.. May be a component in the subframe itself. |
Sun Aug 09 2015 12:09am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8840 |
My seat squeaks where the base rubs against the side of the central tunnel. I can stop the squeak by putting a finger down between seat and the side of the tunnel. I notice that the seat trim here is a suede look which is presumably because of the rubbing that occurs. I keep meaning to put a piece of thin plastic between the seat and tunnel to act as a slip layer and see if it has an effect. 2012 SDV6 - it's missing a couple of cylinders
Sun Aug 09 2015 8:08am |
Sham91 Member Since: 24 May 2018 Location: Bradford Posts: 178 |
RRSTDV8 I have the same issue lol
Thu Nov 29 2018 6:18pm |
