Sidestick
C1A27-14 compressor fault! | |
Hello guys, spent 4 days with my friend (mechanic) trying to solve a problem on a RRS 3.6 V8 i'd like to get for wife.
Car arrived at garage on bumps stop, suspension DTC code C1A27-14, COMPRESSOR CIRCUIT -:C1A27
GENERAL ELECTRICAL FAILURE - CIRCUIT SHORT TO GROUND OR OPEN
At engine start the compressor relay go on for 2 seconds then goes off and the amber light comes up on dashboard.
Changed:
fuse F10 (60A),
relay n°7
fuse F3 (5A)
compressor, (AMK) already changed 1 year ago and firmware updated from LR
without change of state.
Checked continuity on all connectors: behind left driving lamp ,inside NS front wheel arch liner, on Air susp ecu and over compressor bay (+12v and earth).
Problem persist, seems like the air suspension ecu stops the compressor running just after it starts also when the +12v compressor feed connector is open.
Bridging the relay n°7 won't start the compressor,
Feeding compressor with an external battery connected directly on comp bay starts it up and keep it running (near valve block disconnected to avoid overpressure).
No other fault code are present on iidTool.
We have no more ideas on what to check,
i've also read all related topics on the forum.
Help please
Sat Nov 12 2016 9:16am |
