Home > General (L494) > Engine management light? |
Problem,get someone with diagnostics to plug in & see what codes come up.
Sun Nov 25 2018 4:13pm |
J2D Member Since: 28 Feb 2014 Location: Essex Posts: 341 |
It’s an approved used, only had it 2 weeks, so I need to get it recovered? Or is it ok to continue to drive? |
Sun Nov 25 2018 4:22pm |
If you have warranty that includes it, Call out Land Rover Assist, they may recover the car to the nearest dealership and get you a loaner if necessary, but don’t drive it with the light on so that you don’t void any warranty if it is something serious. the first thing LRA should do is read the codes but you can also send them a download over the air by pressing the Assist button in the roof lining above the rear view mirror 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Nov 25 2018 4:24pm |
Spoke to Land Rover assist and looked in the handbook, it’s an emissions fault, but can still drive. If it starts to flash it is more serious and may go into limp mode. As it isn’t flashing they will not call anyone out, and I need to take it to a local LR garage 🙄 |
Sun Nov 25 2018 5:35pm |
IIRC if it is a DPF clogging issue then you would get a red triangle on the dash so if looks like you will be calling the selling dealer in the morning! Good luck with a resolution. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Sun Nov 25 2018 5:41pm |
Thanks Tim,
Sun Nov 25 2018 8:54pm |
andymc Member Since: 04 Jan 2017 Location: london Posts: 127 |
If you've only had it 2 weeks then I'd be laying it on thick with the dealership and get them to collect, fix it and return it to you. SVR with a few bits from Urban and Glohh |
Sun Nov 25 2018 9:50pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 863 |
What are the engine specs ? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Sun Nov 25 2018 9:58pm |
3.0 SDV6 |
Sun Nov 25 2018 10:00pm |
All sorted! Phoned LR assist again and mentioned I was concerned about our safety when driving, and they were straight out. Turned out to be a turbo overboost throttle flap sticking, he had one on the van and replaced it there and then, happy days
Mon Nov 26 2018 6:13pm |
Been-and-dunit Member Since: 15 May 2016 Location: Burton on trent Posts: 145 |
My sdv6 is in one Wednesday for the same light ,I will report back when it's done |
Mon Nov 26 2018 8:09pm |
I hope its as simple as mine. Is yours still under warranty? |
Mon Nov 26 2018 8:55pm |
I hope so as well,yes still manufactures warranty |
Mon Nov 26 2018 9:31pm |
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 |
It takes a very brave man to run a L494 out of warranty............
Mon Nov 26 2018 10:19pm |
