Home > Maintenance & Modifications > is this oil any good |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4788 |
just make sure its the correct C3 or whatever is required
Sat Nov 24 2018 12:20pm |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Second comment on oil in an hour!!!
Sat Nov 24 2018 3:13pm |
removed |
Sat Nov 24 2018 3:47pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 384 |
I have the 2010 3.0 TDV6 so no DPF.
Sat Nov 24 2018 6:42pm |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
That is the exact oil RR gave to me to put in my 3.0 2011 tdv6 so I think you should buy at that price |
Sat Nov 24 2018 8:29pm |
With no DPF that oil is good - A5. We’ll done, good find. |
Sat Nov 24 2018 8:50pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Are you sure? I have a 2010 TDV6 and mine has a DPF. The spec for mine is ACEA C1 to spec WSS-M2C934-B |
Sat Nov 24 2018 10:21pm |
IIRC they were an option in 2010 and fitted as standard in 2011. |
Sat Nov 24 2018 10:46pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
Helix Ultra Professional AF 5W-30 Engine Oil AF matches 5W/30 WSS-M2C913-B or C non DPF Helix AF-L matches 5W/30 WSS-M2C934-B with DPF
Cheers Col |
Sun Nov 25 2018 3:08am |
