Home > Technical > Hydraulic sway bar help. Please see photo
Demaske1
United Kingdom 2009 Range Rover Sport TDV8 HSE Arctic Frost
I have recently had a slight knock when driving in a straight
Line over the odd bump etc. Drop links were replaced which appeared to cure the fault but now another slight knock has returned and on removing the sump guard saw this.The sway bar has a shiny bit sticking out slightly like it’s moved. Is this normal as the rest of the parts look black or dirty with age. There is no sign of leaks from the seals and reservoir has not dropped so it baffles me why this would be shinny silver or is this normal. Anti roll bar bushes look fine also.
Photo is in my gallery for some reason.
Post #568676 Sun Nov 11 2018 11:48am
Brit Plumber
When I changed my front ARB pipes I don’t remember seeing any fescalised portion showing. It looks like it’s being pulled out for some reason. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
Remote Boot close from key fob
2016 Discovery 4 Mirrors AKA RRS2
2014 L405 Surround Camera retro fit (WIP)
2013 RRS Dual View Screen fit (Complete)
2016 LR4 RSE
2014 LR4 Homelink
2016 FFRR Electrochromatic Wing Mirror Glass
70 plate Focus ST (Current)
Post #568682 Sun Nov 11 2018 1:58pm
Demaske1
That’s what I thought but can’t think how ! And it won’t push back in either.
Post #568692 Sun Nov 11 2018 4:50pm
Brit Plumber
I would expect when it’s all connected up, there’s to much pressure on it to move. Hopefully one of the pro mechanics will give you a much better idea. 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #568694 Sun Nov 11 2018 5:22pm
Socast
The roll bar is basically a hydraulic ram that expands and contracts in normal usage (it rotates with the expansion and contraction to create the required forces). Yours is fine Thumbs Up
Post #568758 Mon Nov 12 2018 2:16pm
Brit Plumber
Should it have that fescalised portion showing when at rest as I didn’t see that on mine (it was on axle stands). 2012 5.0 SC AB
Mods:
TPMS
Genuine LR DRLs
2016 LR4 RSE
2014 LR4 Homelink
Post #568769 Mon Nov 12 2018 3:11pm
Socast
It’s chromed and yes. It co tracts when you lean left and extends when you lean right (or vise versa) so when the vehicle is level the bar will be half way extended.
Post #568779 Mon Nov 12 2018 4:00pm
GodivaNige
The ARB doesn’t extend or contract, a piston which is connect to a jack screw, moves longitudinally and it’s motion is converted to a rotational lateral motion via the screw. The section in the photo is the piston. Part of which is external to the outercasing. On older bars, there used to be a boot covering this exposed part, but LR in their wisdom, thought you it would be a better idea to expose this to the elements, grit, salt etc.
Read all about it here... http://www.rrsport.co.uk/gallery/albums/us...tem%20.pdf
Post #568804 Mon Nov 12 2018 8:31pm
Socast
I had looked over that pdf awhile ago, but as you say, I miss interpreted the piston moving internally for a slight contraction/expansion of the arb being converted into the torsional force. But I stand corrected and doth my cap to you Embarassed
Post #568827 Tue Nov 13 2018 12:37am
Demaske1
Bottom arms.
Well after trying to find out what the knock was on my suspension I’ve taken it to Landranger and told me it’s the front bottom arms. Now all I need to do is get the dealer I bought it from less than a month ago to pay for it. Don’t think it will be a cheep job.
Post #568987 Wed Nov 14 2018 10:34pm
