Home > Off Roading & Green Laning > Recovery Points? |
Oh yes.......... saves wellies full of water and wet sleeves trying to remove the covers and attaching the recovery eye if you do need assistance! Even if they are the screw in eye type recovery points which arenβt that great but will get you out. If you have a pre 2010MY / Facelift RRS then you have permanent recovery points well up to pulling the car out that are fixed to the chassis. With my last RRS L494 I only had one recovery eye which seemed a bit pointless so I purchased a second one to have one in place at each end should the worst happen, never needed them in the end. I would be interested to know what the D5 has as RRS and FFRR both have screw in eyes now. If you have a fixed towbar at the back then that can be used too. Removable towbars can do the job but I was always a bit worried it might come adrift at a crucial moment! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Nov 14 2018 11:33am |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1121 |
Yes, I removed the front cover as soon as I bought the car, and the rear has a two attachment with recovery point. --
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 |
Thanks.
Wed Nov 14 2018 11:58am |
Standard recovery points are plenty strong enough, see link below
Wed Nov 14 2018 1:17pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8834 |
No recovery points used I that video, Chris. They bolted straight to the chassis.
Wed Nov 14 2018 6:08pm |
spoil sport! They are very strong though 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Wed Nov 14 2018 6:20pm |
2012 SDV6 - it's missing a couple of cylinders
Wed Nov 14 2018 6:57pm |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 410 |
My MY17 has a fixed eye at the front. The screw-in eye is for the rear (or you could use the towbar). RRS MY17 SDV6 AB Evoque MY17 TD4 AB |
Wed Nov 14 2018 10:31pm |
