Home > Technical > Car Key Fob Signal Blocking Pouch/Bag/Case |
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 527 |
Yes.... it stops the car key communicating with the car when it’s looking for a response... so you place the key in the bag at night or if you are going to be away from the car. You will need to remove it from the bag to be able to open the car and start it. |
Sun Nov 11 2018 11:24pm |
Smunns Member Since: 06 Nov 2018 Location: Surrey Posts: 61 |
That is what I was thinking so if I was to put the key in it and walk up to the car with the bag it should not be able to open the car?
Mon Nov 12 2018 6:30am |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
I have my keys in a metal tin but after watching that programme I took the tin out to the car and if the tin was at window level the car unlocked so I've been looking at buying one of these bags but if that's the same then what's the answer ? 2017 SVR. SVO Scafell grey Ebony interior
Mon Nov 12 2018 7:25am |
I have a faraday case that I keep both keys in & ive stood next to the car with the case & both keys & it wouldn't open so I know mine def works.What sort of case have you got,the one I got came from a recommendation off this forum & came from amazon.
Mon Nov 12 2018 7:53am |
The bags have two pockets which are not obvious...open the bag fully and place the keys in the rear most pocket between the faraday lining...
Mon Nov 12 2018 8:03am |
I got my one off eBay and have tried both pockets thinking it might make a different but does not so take it I brought a door ledge instead then lol. |
Mon Nov 12 2018 8:07am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
I did exactly this when I got mine, obviously didn't work. Put the key in the actual pocket and it works fine. I bought two, the spare key lives in the other one in my safe. |
Mon Nov 12 2018 10:04am |
Will have to try it again later and maybe film it or the pouch I have is rubbish lol |
Mon Nov 12 2018 10:46am |
I only know this from finding out the hard way myself...it’s really not obvious but you need to slide the key between the sheets! |
Mon Nov 12 2018 8:54pm |
