Home > Technical > 2010 Towing Electrics Curveball |
It comes off quite easily compared to other trims on the vehicle. 2012 5.0 SC AB
Fri Oct 12 2018 12:41pm |
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 |
Took the bumper off today to see the wiring.
Tue Oct 16 2018 1:23pm |
Not sure what that wiring would be but if it’s part of the loom that attaches to that green plug and exits the vehicle via the big grommet and runs to the PDC sensors etc then yes it should. That existing loom goes in the bin or bottom draw and the new one replaces that and has the extra wiring for the trailer. 2012 5.0 SC AB
Tue Oct 16 2018 6:16pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4843 |
You haven't actualy said what you have ordered, if you have ordered the correct kit from L/R then yes it should, if it's for a MY12 on probably not as it's in the link harness already fitted to the car, look at page 4 of the PDF for the MY10-11, if it's a pattern part or something of eBay then wouldn't know.
Tue Oct 16 2018 8:06pm |
I have ordered this
Wed Oct 17 2018 10:55am |
That kit will come with everything you need. You’ll now have an extra 13 pin connector loom (your original purchase) which you can now sell on. 2012 5.0 SC AB
Wed Oct 17 2018 6:06pm |
All sorted and working.
Wed Oct 31 2018 9:45pm |
2012 5.0 SC AB
Wed Oct 31 2018 9:58pm |
