Home > Technical > Hunter Wheel Alignment |
amgmaj Member Since: 28 Nov 2017 Location: Nottingham Posts: 79 |
Ok thanks @Tyrefitter |
Fri Oct 26 2018 6:20pm |
Just checked I don't think I have dynamic response on my range rover sport 3.0 2010
Fri Oct 26 2018 6:38pm |
No it doesn’t look like you have,,yours is one of the models I haven’t had,I went straight from a 08 to a 12 plate.
Fri Oct 26 2018 6:42pm |
Thanks once again mate |
Fri Oct 26 2018 6:44pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
That one should be ok if you don’t have dynamic.
Fri Oct 26 2018 6:52pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2006 |
Did they lock it in Tight Tolerance Mode with a plug in diagnostic? If not, then forget it. All air suspension vehicles need putting into TTM for 4 wheel alignment.
Fri Oct 26 2018 6:54pm |
Yes software all countries I was next to the screen when he was doing the alignment. Which RRS 2.7, 3.6, 5.0 setting should I go with when I take it back tomorrow if he can't a RRS 3.0 setting? Last edited by amgmaj on Fri Oct 26 2018 8:29pm. Edited 3 times in total |
Fri Oct 26 2018 7:10pm |
I put it in TTM myself outside the garage with IID Gap tool |
Fri Oct 26 2018 7:11pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8800 |
Yours may have dynamic response. Dynamic response is the name of the hydraulically activated ant roll bars. Dynamic mode is part of the Terrain Response system. Different things, I'm afraid, and often confused even on here.
Fri Oct 26 2018 8:01pm |
Wot he said ^^ Visitor from fullfatrr.com
Sat Oct 27 2018 6:46am |
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 |
I had my castor/camber/toe done on a Hunter machine last week, as it seemed to be pulling to the left slightly, and steering wheel off centre too. This was after I had the lower front suspension arms changed and geometry had been done.
Sat Oct 27 2018 10:29am |
All sorted now steering wheel straight and no pulling towards the left
Sat Oct 27 2018 5:20pm |
Could you please tell me if my RRS has Dynamic response by looking at the pictures of my engine bay? |
Thu Nov 01 2018 5:18pm |
It’s the big yellow cap in the centre bottom of the second photo. 2012 5.0 SC AB
Thu Nov 01 2018 5:28pm |
