Home > General > Smell of Exhaust Fumes in Cabin |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 |
Not the clutch making a burning smell?! 2019 Svr and 2019 R35 GTR |
Fri Oct 19 2018 1:58pm |
Is it a 5.0 SC? I have a smell that comes in the cabin when I boot it. 2012 5.0 SC AB
Fri Oct 19 2018 2:02pm |
215m3 Member Since: 13 Sep 2018 Location: Cambridge Posts: 48 |
I wish a SC, sadly TDV6
Fri Oct 19 2018 2:14pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 746 |
Leaking exhaust? Is it blowing at all? Worst case would be a fractured exhaust cross-over pipe, (have a search on here or Disco3) a real PITA to change body on and not cheap for what it is. |
Fri Oct 19 2018 6:03pm |
Thanks
Fri Oct 19 2018 9:13pm |
MAC Member Since: 08 Dec 2006 Location: Suffolk Posts: 60 |
My daughters 2011 RR Sport has the same issue. Although it has LR extended warranty they will not cover the cost. Initially they said it was due to it being part of the exhaust system. It was pointed out it was actually part of the exhaust manifold system connecting the manifolds to the turbo. They then had a change of heart and said it was not covered due to wear and tear!
Tue Oct 23 2018 3:33pm |
Hi Mac
Tue Oct 23 2018 5:35pm |
Hopefully all will be ok then. Quotes received so far for replacing the crossover pipe are in excess of £1,000. |
Wed Oct 24 2018 9:28am |
That is useful information. Apparently to test the front pipe start the car, leave to run for 3 minutes and if the engine tone changes it could be a crack in the pipe. It is because the flow changes from one turbo to the other. 2010 3.0 TDV6 RRS Overfinch GTS
Wed Oct 31 2018 9:42pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4333 |
Correct. TSOV is closed, which stops the secondary turbo from spinning.
Wed Oct 31 2018 10:30pm |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 |
My warranty has been a life saver and never had an issue with any claims on it whatsoever |
Wed Oct 31 2018 10:32pm |
Willis1987 Member Since: 20 Dec 2021 Location: North wales Posts: 4 |
Hi what warranty is it you have? Thanks Matt |
Wed Jul 12 2023 7:46pm |
