Home > Technical > Is it possible to reverse the adaptive cruise default?
PompeyDave
Hi all, I've had a RRS for about three months now and I can honestly say its the best car I've ever owned. I absolutely love it. I have a 2010 facelift 3.6 v8 diesel, and have just a couple of small annoyances- the door mirrors dipping in reverse is something I don't need- is there any way to disable it? Also I love the adaptive cruise, but I wish the default distance to the car in front was set at the shortest length, not the longest- is there any way to change it?
Post #566874 Sat Oct 13 2018 9:43pm
You can adjust the ACC with the steering wheel controls, and switch mirrors dipping in reverse off in the menu settings if I remember correctly.
Post #566875 Sat Oct 13 2018 9:48pm
PompeyDave
Thanks Col, yep I know I can adjust it to the shortest distance, but I'm having to do it every time I set the cruise. It's a real pain.
Post #566876 Sat Oct 13 2018 9:51pm
Have to admit I hate the ACC and never use it, didn't realise it defaulted back to furthest distance each time it switched off.
Post #566877 Sat Oct 13 2018 9:57pm
PompeyDave
I'll check the menus for the dipping door mirror options, thanks!
Post #566878 Sat Oct 13 2018 10:00pm
I think it's in Vehicle Set Up. Thumbs Up
Post #566879 Sat Oct 13 2018 10:09pm
Brit Plumber
For mirrors, put it in reverse and then set the mirrors to where you want them for normal driving. That way they stay where you want them and they won’t change. 2012MY RRS 5.0 Supercharged Autobiography (Current)
67 plate Focus ST Line (Current)
09 Mondeo 2.2 Titanium X Sport (Current)
02 Ford Focus TDCI (Brilliant car sadly scrapped)
99 BMW M3GTII (Amazing car, written off By a Fiat)
Post #566882 Sat Oct 13 2018 11:44pm
When I used adaptive cruise - which I think is fab - I found the shortest distance was akin to automated tailgating. Why would you want to sit so close to the rear of another vehicle? 2012 SDV6 - it's missing a couple of cylinders
Post #566885 Sun Oct 14 2018 12:15am
Personally found it easiest just to switch mirrors off in set-up menu, few presses of the button. What I did was set them where I wanted them in reverse if I needed them, then just turned them off so can reactivate them by using menu if needed, without having to re-adjust them.
Post #566887 Sun Oct 14 2018 12:20am
insiorc
Scotland 2013 Range Rover Sport SDV6 Autobiography Firenze Red
^^^^ Exactly
I always adjust mine to furthest distance, mine defaults to one of the middle distances. If I had somebody tailgating me as close as the shortest setting I'd be slamming my brakes on to tell them to back off! 13MY Range Rover Sport Autobiography SDV6 - mine
14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's
99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite
Post #566911 Sun Oct 14 2018 9:55am
Snow White
Mine is supposed to have adaptive cruise control, but so far I haven't found it in any of the setting.
Would someone be kind enough to point me to where abouts in the various setting I might find it?
Or can I enable it using IID?
Ta RRS 2012 HSE Lux Alive stage 1 remap. timed heater
D3 with BAS & general grabbers (gone)
Defender with 3 winches and other sutle mods
Post #566915 Sun Oct 14 2018 10:02am
Do you have the switch on the L/H the side of the steering wheel with the arrow markings on it, if not you haven't got it.
Post #566920 Sun Oct 14 2018 10:20am
Snow White
Ahh. Mr. Green
I don't have it. I'll stop looking then!! Big Cry
Ta Bow down RRS 2012 HSE Lux Alive stage 1 remap. timed heater
Post #566927 Sun Oct 14 2018 11:19am
PompeyDave
Well my shortest distance is about three car lengths in front. The problem I have is that at the default maximum length I fall further and further behind the car in front as each driver pulls out in front, causing me to drop further back. Then another pulls out and so on...
Post #566983 Sun Oct 14 2018 8:44pm
PompeyDave
Ok, I’ve adjusted the mirrors in reverse to match those settings going forward, so thanks for that little tip. One other small niggle- the sat nav voice volume is set to ‘ears bleed’ level- is there any way to turn it down rather than manually at every instruction?
Post #567203 Wed Oct 17 2018 6:53pm
