Home > Technical > Red triangle and restricted performance. |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Have you checked all the wiring and connectors? 2012 5.0 SC AB
Thu Sep 20 2018 9:47pm |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
I have checked all the wiring that I can see which seems to be in order and all connections checked.....I have also sprayed contact cleaner on all the connectors I can see but this has not made any difference. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Fri Sep 21 2018 11:32am |
I'm off to main Range rover dealer to put car on diagnostics. I did show them my diagnostics from the bt iid tool but surprise surprise THEY need to put it on theirs for about 100 euros. Seen as I can't find problem either myself or via forum members I'm forced down this cut de sac. (No indies in my area !!)
Wed Oct 10 2018 9:47pm |
OK....I took the car into JLR and left the car with them to do the diagnostics and hopefully solve this ongoing problem.
Thu Oct 11 2018 4:41pm |
