Home > Technical > AJD-V6 Crankshaft Recall |
Revoke Member Since: 03 Sep 2017 Location: Gainsborough Posts: 14 |
Mon Oct 08 2018 1:05pm |
Thanks to google translate:
Mon Oct 08 2018 2:22pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
Amazing that this is happening in South Korea but not elsewhere in the World, wake up Land Rover and do the right thing and stand by your product ! |
Mon Oct 08 2018 3:51pm |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
I was using the landrover SDD Diagnostic software to active times climate on Saturday and there was a bulletin in regards to the tdv6 engine failure and a customer concerns section , i hadn't seen it before but I will check it out to see if they are acknologung there is a fault |
Mon Oct 08 2018 5:18pm |
https://www.jaguarkorea.co.kr/index.html
Mon Oct 08 2018 5:26pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
I would call this EU customer discrimination, Shame on JLR! RRS 3.0 SDV6 HSE Lux
Fri Oct 12 2018 6:05pm |
Seems very strange only they would be doing this and not anyone else 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Sat Oct 13 2018 8:19am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
The part I don't really understand is, they will do a fault diagnosis to determine if engine requires replacement fair enough, they also say the diagnosis will take about an hour, again fair enough, but there is no way they can remove the sump to check the crankshaft and bearings and refit in a hour, so if it only takes a hour to determine if it requires a engine change they must know what to look for as the tell tale signs, and if that is the case then why the hell can't L/R check U.K vehicles, unless of course they think they will find to many that need replacing. I did think the first people knew of the issue was when the vehicle stopped abruptly, I am prepared to accept I might be talking complete and utter rubbish though.
Sat Oct 13 2018 8:51am |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Maybe they can do it from debris sampling the oil. That’s how they do it on aero engines and it’s very accurate. 2012 5.0 SC AB
Sat Oct 13 2018 9:19am |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 |
Surely, if the failures are indeed down to bearing shells rotating and covering up oilways, there would be no debris until very shortly before the end?
Sat Oct 13 2018 12:14pm |
Possibly excessive crankshaft end float, could check that at front pulley.
Sat Oct 13 2018 7:45pm |
