Home > Maintenance & Modifications > Front Inner driveshaft boot 2.7 tdv6 |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
Give it a good wash with soapy water then cover it in tyre dressing, silicon grease or a similar product for rubber. Let it soak in and reapply where it dries in. After a few hours wipe off the excess. That should help it for a while, it is only an advisory and a good clean and treatment may keep it going for years. 2012 5.0 SC AB
Sat Oct 06 2018 11:13pm |
HEFF Member Since: 14 Jan 2018 Location: from southampton - now in Durham :( Posts: 105 |
thanks for the reply,but i was hoping to change it for a new one. |
Sun Oct 21 2018 5:44pm |
In that case I think there’s only one real option and that’s to pull the drive shaft. If it was an outer you can get a stretchy boot that goes over the outer CV joint to save pulling it of the shaft. But as an inner, I think you need to drain the oil, pull the drive shaft, remove inner CV joint, replace boot, refit inner CV joint with new split ring, refit shaft, fill with oil. 2012 5.0 SC AB
Sun Oct 21 2018 6:52pm |
thanks mate appricate the help.im due an oill change so will try to fix it at the same time. |
Thu Oct 25 2018 8:57pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
An opportune thread - checking under my car yesterday I noticed one of my inner boots had perished next to the driveshaft end clamp and just a little CV grease had oozed out. I was hoping someone said that there was a split boot available as a replacement but I guess not. My lower suspension arms need doing so it looks as if the shaft will have to stay in until the suspension is done.
Thu Oct 25 2018 11:46pm |
hi Garry yes a split boot would be a lot easier,but i think there not as strong as a hole one .good luck with the job. im going to order parts next week hopefully if i get to start my new job. fingers crossed. |
Fri Oct 26 2018 5:25pm |
Thanks - i have had mixed reults using split boots on different vehicles - didn't work on a subaru I used to own but I have them on the Haflinger I currently own and they are great.
Sat Oct 27 2018 1:39am |
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 |
HEFF, this split boots are supposed to be one of the best -
Sat Oct 27 2018 10:29am |
oh ok, i dont know but if the split boot works then great that will help a lot.
Sun Oct 28 2018 6:06pm |
A split boot is a lot easier but it will not last as long as a oem boot so unless it is completely clean and clear of all rubbish/dirt then i would have it done correctly we used to offer this service but you cant guarantee the length it will last |
Sun Oct 28 2018 6:32pm |
thank you geoff that clears that up..but is it a big job |
Wed Nov 07 2018 8:58pm |
