Home > Maintenance & Modifications > How To - AMK Suspension Compressor Replacement |
liverpool_luke Member Since: 03 Nov 2015 Location: Liverpool Posts: 7 |
When the Indy did the update with autocom (assuming this is capable?) He did ask does the car have blah bla blah (mutter English couldn't hear him) he poped the bonnet and said no you don't have it, wonder if he referred to arc ? What is it how would I tell I have it? With thabks |
Sat Dec 05 2015 10:27am |
won't mention any names, went back to the garage that was paid to update the firmware (knowing that the firmware install was only 6XXX) spoke to the guy who said you sure I updated it as I don't remember putting a battery charger on last time !
Tue Dec 08 2015 8:54pm |
Joser Member Since: 17 Feb 2016 Location: California Posts: 3 |
Wed Feb 17 2016 2:14am |
For better or worse I didn't use that bit or cut the pipe, didn't feel comfortable cutting them, I left them.the original length and placed them so there was no kinks anywhere |
Wed Feb 17 2016 8:57am |
Ok cool thanks for the info this thread has helped me alot |
Wed Feb 17 2016 1:36pm |
Daztrex700 Member Since: 07 Jan 2017 Location: Telford Posts: 6 |
After installing new pump do you need to clean out the 4 air valves for each corner of the car? Don't know the name of them. Thanks |
Sat Jan 07 2017 1:05pm |
Sat Jan 07 2017 1:09pm |
Are you referring to the valve blocks? If so im pretty sure the are only three when i replaced my pump i did not do it. |
Sat Jan 07 2017 9:44pm |
Yes that's it thanks |
Sat Jan 07 2017 10:05pm |
Sun Jun 17 2018 11:06pm |
Mon Jun 18 2018 9:48pm |
Mon Jun 18 2018 10:37pm |
Chrispiec Member Since: 23 Sep 2018 Location: Glasgow Posts: 3 |
Hi guys,
Thu Sep 27 2018 10:30pm |
