Home > My Range Rover Sport > Soon to be an owner. |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
What engine is it? 2012 5.0 SC AB
Wed Sep 19 2018 6:43am |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 465 |
It's the 256hp 442 lbs-ft torque
Wed Sep 19 2018 8:32am |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Welcome - any pics or links to your new purchase ? 16MY Estoril Blue SVR.............
Wed Sep 19 2018 8:56am |
I will put a couple of pic's up tonight, but the seller has removed all advertising so no links..
Wed Sep 19 2018 9:17am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4833 |
Have a good look at the wheels for cracks etc., if they are 22" style Seven they are copies as L/R never fitted 22" rims to the L320. Cheers Col |
Wed Sep 19 2018 9:51am |
Good spot, I know that they are brand new wheels and tyres, but I will ask them where they come from and if they are OEM, but for the newer model, or replica ones,
Wed Sep 19 2018 10:04am |
LeeRRS Member Since: 19 Nov 2015 Location: UK Posts: 43 |
check the suspension very closely. take it for a good run, then get under it and check for fluid leaks. 2012 Range Rover Sport Autobiography 3.0 SDV6
Wed Sep 19 2018 12:42pm |
Thanks Lee,
Wed Sep 19 2018 1:00pm |
no problem
Wed Sep 19 2018 1:04pm |
Test the high /low transfer box change over works smoothly and quietly - start the engine, select N, open driver’s window, press Hi/lo button and the change should occur......... or not if the car has not been used properly. Check the indication lights illuminate on the dash and in the 4x4 info screen then shift it back to high ratio. It isn’t a huge issue to fix, it just shows the previous owners never maintained the car according to the manual, it is a negotiating point if it doesn’t shift in and out smoothly and quietly, you are buying a hugely capable off road vehicle,even if you don’t intend to go further offroad than the golf club car park all the off road bits should still work properly.
Wed Sep 19 2018 2:51pm |
Hi Tim,
Wed Sep 19 2018 3:07pm |
Bill Portland Member Since: 01 Feb 2017 Location: Dorsetshire Posts: 387 |
fob for remote climate control(heating and cooling)
Wed Sep 19 2018 4:23pm |
Check the climate control cools as well as heats - there is no need to switch it off, just leave it in auto but there are a lot of misguided people out there who think running it all year round consumes extra fuel, it doesn’t these days now systems are more efficient. You do more damage to electronics switching it off because the dehumidifier doesn’t run when the climate is switched off, it works regardless of whether you have a warmer or a colder temperature set. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Sep 19 2018 5:03pm |
Are you sure about that Tim? I certainly notice a drop in mpg when I have the Aircon on. Merc C220 estate Sport AMG
Wed Sep 19 2018 5:45pm |
