Home > Maintenance & Modifications > RR sport sc 2005 start / turn over issue
Paulo 61
England 2005 Range Rover Sport Supercharged Java Black
Hi all,
Have an issue with my 2005 RR sport sc, when I turn the key to start it dose its checks but doesn't always turn over first time I have to turn key back then retry sometimes two or three times, It has always started and when it turns over it is at a good rate. Will check battery connection tomorrow but I don't think it is that as when it dose it the lights on the dash don't show signs of dimming ,
Wondered if anybody had come across this before.
Thanks
Paulo
Post #565175 Fri Sep 14 2018 8:57pm
Change relay by battery marked SM
Could use the rear blower relay if it's the same
Post #565176 Fri Sep 14 2018 9:45pm
Paulo 61
Thanks Andy I will give that a try and let you know how I get on Thumbs Up
Post #565191 Sat Sep 15 2018 9:01am
Paulo 61
Update was out for most of the day but when I got back had a look at the RR. Checked battery connections found the positive was not as tight as it should be. Then I changed the starter relay over with another one which was the same. Neither of these things sorted the problem. I suppose the next thing is the starter motor or the ignition switch ,problem is it doesn't do it every time.
Post #565283 Sun Sep 16 2018 7:26pm
Site Copyright © 2005-2018 Futuranet Ltd & Martin Lewis
