Home > Technical > is this all battery related? hdc gearbox park brake |
Your battery is knackered buy a new one you will get there in the end anyhow |
Wed Sep 12 2018 4:26pm |
W18ODY Member Since: 31 Aug 2014 Location: north east Posts: 87 |
looking at betteries seems the enduroline and the exide are both common, anyone got a preference?
Wed Sep 12 2018 5:01pm |
As long as its an agm and has a long guarantee |
Wed Sep 12 2018 6:07pm |
As well as AGM you should also consider a higher CCA battery if your car sits outside all winter, cold weather has less effect on high cold crank amps batteries when you are starting up. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Wed Sep 12 2018 6:13pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8837 |
Doesn't need AGM. Standard battery is fine. Go for something 100Ah 900A.
Wed Sep 12 2018 11:34pm |
cheers for the replies everyone!
Thu Sep 13 2018 10:32am |
Fairly sure the RRS diesel needs a 019 battery, although the little engine versions might be 017, not sure. 2012 SDV6 - it's missing a couple of cylinders
Thu Sep 13 2018 11:33pm |
new battery arrived friday great service from tayna, so far so good! cheers for the help everyone! |
Sun Sep 16 2018 2:06pm |
