Home > General > 2.7TDv6 Am I buying a ticking time bomb |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 |
I bought a 2005 RRS TDV6 in 2016 with 109K miles on it and FSH. Like you I was concerned it may go bang and be very expensive to repair but apart from a couple of very minor issues, it ran perfectly all the time I had it. I sold it recently because I retired and had to go down to one car. I do miss the comfort and high driving position but don't miss the 27mpg (my new car will do twice that). |
Tue Sep 11 2018 8:17am |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8827 |
Is it a problem? Yes. Is it likely to fail? No, not really. There are a lot of 2.7 on the road (in both RRS and Disco) and they're not lunching their engines every five minutes. One problem with forums like this is that people often only go on them when they have a problem so the "aargh, help!" traffic is disproportionately high. 2012 SDV6 - it's missing a couple of cylinders
Tue Sep 11 2018 8:28am |
Fictivision Member Since: 31 Oct 2015 Location: Molde Posts: 31 |
I bought mine 2006 in 2015 with 180000km now it have 235000km.No issues. |
Tue Sep 11 2018 10:29am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1239 |
We bought ours at 36k a year and a half ago and today it has passed 57k, its our daily driver. I had no idea about the engine issue until after I purchased the car and I also did give it some thought, but as mentioned above if you think how many are out there......
Tue Sep 11 2018 10:45am |
There is no when it will go it is an if it will go i believe the earlier cars like 05/06 where less likely as the oil pumps were better as to the mileage if they go there is no set mileage they have gone with low miles and also with high mileage it is something to do with the bearing's being starved of oil then rotating on the crank and it also seems that when the belts are changed and oil pump together then sometime's they let go i think the bigger issue is the fact that it is £4/5 for a new block plus everything else i had i disco 3 bought with 113,000 on the clock and sold it with over 140,000 with no issues |
Tue Sep 11 2018 11:08am |
Tom_w_27 Member Since: 09 Sep 2018 Location: Norfolk Posts: 40 |
Thanks for the input much appreciated |
Tue Sep 11 2018 9:14pm |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 405 |
Hi Tom. I'm simply going to paste a posting I did the other day...
Fri Sep 14 2018 5:13pm |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1061 |
A 12 year old car with almost 120,000miles on it is not ticking time bomb - need to be realistic - it isn't new and will have some issues develop simply because of its age but it has got this far inits life so is no ticking time bomb. 07MY RRS TDV6
Sat Sep 15 2018 1:20am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I think the only problem is the cost if an engine fails as this can more than the car is worth, plus JLR extended warranty will not cover crank failures.
Thu Jun 06 2019 9:59am |
Not a ticking time bomb but 100% all will be down to observing service schedules and good maintenance by previous owners. These are expensive car to buy and complex and expensive to maintain result is a big incentive to neglect them until something fails once they get a few years/miles out of warranty. There is no such thing as a cheap to run Land Rover product. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 06 2019 3:25pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
I completely agree re. the injectors. When my TDV6 spun a main bearing, 3 of my injectors were out of spec when they were sent away to be tested. I'm now considering getting them tested on a periodic basis to help prevent such issues happening in the future. Kev MY2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey MY2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Thu Jun 06 2019 10:08pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1048 |
I've put over 60k on mine since purchased and I've had no engine issues whatsoever. I have had to replace the MAF, EGR (blanked) and a turbo pipe though but the engine has been sound, sitting on 156k or so now. There have been various suspension issues but on such a heavy car and the abuse I give it on/off road then I consider that as consumable stuff. |
Sat Jun 08 2019 10:04pm |
Stand Easy Member Since: 10 Aug 2016 Location: Manchester Posts: 123 |
Bought mine in 2016 with 193000 on it, extensive service history from previous owner and now has 214000, I'm changing it this weekend for a 2010 3.0 but had no engine issues at all. |
Tue Jun 25 2019 11:08am |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 |
just gone through 325,000 miles, 1 owner from new. At each camshaft belt change I get oil and water pump changed and all idlers and tensioners.
Mon Jul 15 2019 10:11pm |
