Home > Tips & Tricks > How to replace the front seat base foam |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1847 |
An update to this thread, I bought a set of seats from a 2013 MY sport which I think may have been from an SE or HSE. The base foam is Pt No. HGB500050 and the base cover is dated 17 Sep 2012 on one side and 16 Aug 12 on the other. I suspect the HGB500050 is actually for the lower spec seat and LR021399 is for the higher spec seat.
Thu Jul 19 2018 12:10pm |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 |
would anyone know the part numbers for front heat seat pads ? for driver and passenger front ?
Wed Jul 25 2018 3:01pm |
bump
Mon Aug 20 2018 9:41am |
Could be this one lr016245
Mon Aug 20 2018 1:10pm |
excellent thank you |
Mon Aug 20 2018 2:30pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4817 |
Used to be HGL500020 same drivers and passengers, but number may have been superseded by now. I think LR016245 is for the facelift although LR016246 is the one I used when I replaced mine on a MY13 A/B as said was for Leather/Alacantara, which I believe is a type of Suede and the 245 was for Leather/PVC but could all be the same part number now.
Mon Aug 20 2018 10:22pm |
thanks Col - I used the site in the picture - and came back with the part numbers you have there. |
Tue Aug 21 2018 8:37am |
Not sure what that site is as can't read address fully, but I got the numbers from L/R's microcat parts list.
Tue Aug 21 2018 8:45am |
From what I’ve been seeing, there doesn’t appear to be a pre or post facelift version. There appears to be a low spec and high spec version throughout production. As shown in one of my posts above, I picked up a 2012 interior with what we believed were pre facelift cushions and heater pad. All dates are from the same month and year as the facelift seat controls and frame etc. 2012 5.0 SC AB
Tue Aug 21 2018 10:39am |
According to L/R's own parts system they are different between pre-facelift and facelift variants, there is no mention in the parts list of a difference between a SE, HSE OR A/B. If I remember correctly the seat trim panels are a different layout between the two which could account for the difference in the seat cushion foam.
Tue Aug 21 2018 11:06am |
fitted my new heater pads and cushions at the weekend - very very happy. Much thanks to everyone |
Tue Sep 11 2018 10:15am |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1138 |
Sorry to ressurect an old thread but I just thought I'd let you guys know I replaced my driver's seat base today.
Wed May 27 2020 8:24pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 916 |
As you say,, well worth doing, and certainly made so much easier thanks to slims detailed description on how to do it otherwise I doubt I would have tried it. I got mine from Duckworths but I fitted a new heater as well as knowing my luck it wouldn't have come away from the old foam. 2010 RRS, TDV8
Thu May 28 2020 7:59am |
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 310 |
Hi Slim 444 - I read your post regarding the removal of the driver seat with interest!! Just to make sure I understand, I have a 2006 Sport and need to check out the wiring under the seat......I presume from your post you managed to remove the seat (just the part you sit on) without having to take out the whole chair? Is that correct? I had a look under my seat this morning it would seam to be a very difficult job if at all possible?!? Would be grateful for your feed back.....Andrew Andrew Kennedy |
Sun Jun 07 2020 12:14pm |
