Home > In Car Electronics > Cd player problem |
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 |
You likely have dirt on the CD pick up lens.
Sat Aug 11 2018 5:28am |
Paratrev Member Since: 17 Jan 2018 Location: Nottinghamshire Posts: 5 |
Thank you for your answer, I will give that a go at next opportunity and post the result, thanks again. |
Sat Aug 11 2018 8:16pm |
Well, took the stereo unit out and cleaned the lens unit which to be fair was clean, put it all back together and refitted.
Thu Aug 16 2018 9:03pm |
If it was all clean inside, not just the lens and pickup, but I’m guessing you could also see the transport was clean too, then the likely outcome is a faulty unit. Could be time to bite the bullet and buy another one. |
Thu Aug 16 2018 9:52pm |
It looked clean, nothing obvious, its almost as if the wrong type of cd like a playstation etc disc has been inserted to give the invalid disc message
Fri Aug 17 2018 7:59am |
