Home > In Car Electronics > Sat nav stopped working - "no nav available" messa |
Yorkie09 Member Since: 15 Aug 2018 Location: Braintree Posts: 7 |
Sat nav was working fine, wife cleaning behind passenger seat and disturbed the retro fitted multimedia Video Interface Unit, now have "no nav available" message on screen. Have run 753 diagnostic and it reports DTC U1A0131 GVIF Signal Fault.
Wed Aug 15 2018 8:43pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4777 |
Check the GVIF IN OUT connectors.
Wed Aug 15 2018 10:31pm |
It doesn't look possible to insert the connector upside down?, I disconnected it and reinserted it the same way.
Thu Aug 16 2018 11:44am |
The blue connector that goes into the rear of the nav unit itself can go in upside down if you disturbed that one as well |
Thu Aug 16 2018 4:06pm |
The no nav message appeared before I removed any of the connectors, was working fine before the MM interface unit was disturbed. |
Thu Aug 16 2018 6:43pm |
Fantom Sport Member Since: 27 Feb 2021 Location: Surfleet Posts: 8 |
Did you fix the problem. Mine says exactly the same after removing my Radio and touching the interface box. |
Mon Apr 19 2021 8:52pm |
