Home > Maintenance & Modifications > L320 2010 turbo actuator |
Godders Member Since: 26 Aug 2017 Location: Dordogne Posts: 155 |
I have started a new post for future reference and it is in regard to the turbo actuator.
Wed Aug 15 2018 6:49pm |
I think the actuator is still sticking |
Wed Aug 15 2018 6:54pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4334 |
None of those faults are related to the turbo actuator... |
Thu Aug 16 2018 6:54am |
can you point me in the right direction as to the actual problem ? Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Thu Aug 16 2018 8:15am |
P22D4-17:
P22D4-17:
P22CF-71:
Clearly, there is an issue with the turbine intake solenoid or its associated circuits The solenoid is at the top RH of the engine as you look from the front. This controls a set amount of vacuum to pass to the valve itself. If you have had any work done recently, a Vac pipe having been knocked off or disturbed would be the first place to look |
Thu Aug 16 2018 9:27am |
Mikey, I have had a look at the solenoid and all appears in order with the electric wires in order and connected together with the vacuum pipes all connected and don't appear perished or damaged. Is it worth getting in a new solenoid as there is an original new land rover part for sale at £14.99 ?
Fri Aug 17 2018 3:47pm |
Ok I have now put a new solenoid on and this obviously cured two of the original problems/readings given and the following readings are now showing:-
Wed Sep 19 2018 12:29pm |
jaxone Member Since: 26 Oct 2018 Location: Globe Posts: 2 |
Hi Godders.
Fri Oct 26 2018 7:45am |
I have been to JLR in France where I live and they know that the problem is an electrical one between the two turbos.
Fri Oct 26 2018 9:51pm |
Thanks for getting back to me.
Fri Oct 26 2018 10:57pm |
will do Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Sat Oct 27 2018 11:08pm |
AT LAST.... having been into JLR in France just before xmas they did their own tests and initially came back saying both turbos need doing OMG !! I wasn't happy and questioned them with my own diagnostics reading. (this garage in France has Jaguar , Land rover and Volvo cars....and apparently all the mechanics work together and help out which may have meant that it was not a Landie mechanic looking at my car.) I did ask for a quote for the work...just for a laugh but two days later they called and asked to have the car back in for a day to do further checks. Well today was the day and they tested both turbos which are fine and confirmed it is the actuator (although they called it the command of the turbos) and quoted 1,500 euros to do the work. They explained that of the two turbos, there is a smaller one and a larger one...and it is the actuator on the smaller turbo that is having the problem. Part being ordered and hopefully arriving tomorrow and work done in next couple of days. Never argue with stupid people, they will drag you down to their level and then beat you with experience. |
Mon Jan 07 2019 5:39pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1243 |
Good on you for preserving when you thought you were right
Mon Jan 07 2019 7:19pm |
Got my car back today and no red light. Have then completed a drive of roughly 100 miles on fast single lane roads and motorway and all is running as should be.
Thu Jan 10 2019 11:32pm |
