Home > Technical > What is missing from here? |
I’ve now found out that the connectors are for the rear differential control module. So should a 5.0 Supercharged have one of them? 2012 5.0 SC AB
Fri Aug 10 2018 11:15pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4840 |
The three loose connectors, Yellow, Purple and Black are for the Rear Diff Control Module which I assume are only used if you have the Electronic Locking Rear Diff fitted. The purple connector should be a 15 pin plug with just a pair of can bus wires one in pin 2 and the other in pin 5. The yellow plug should be a 8 pin and the black one 18 pin. As for the extra wires wouldn't have a clue, although when had a tracker fitted that's where they fitted the unit, so may have been something along those lines, but would have hoped for a more professional job than that bodge.
Fri Aug 10 2018 11:25pm |
Beat me to it. The locking diff was a £750.00 option on all variants except factory pre facelift HST's. Cheers Col |
Fri Aug 10 2018 11:27pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8840 |
It is actually possible to retrofit the locking rear diff - a chap on Disco3 did it some time ago as I remember. A bit of wiring required but other than that and the CCF update, it was good to go. 2012 SDV6 - it's missing a couple of cylinders
Sat Aug 11 2018 12:52am |
Might work out bit expensive unless you can get used parts, new diff alone would be over 2k + surcharge unless you had old one.
Sat Aug 11 2018 4:37am |
I didn't say it would be cheap, just possible. This is LR - their spares are ridiculously overpriced these days when you look at some of the OEM prices for the same item. Sadly, I'm not aware of diffs being available OEM. 2012 SDV6 - it's missing a couple of cylinders
Sat Aug 11 2018 8:43am |
Does the Sport really need a locking rear diff? If it did, wouldn't they have fitted it as standard? 2012 5.0 SC AB
Sun Aug 12 2018 7:56pm |
The reality is that 99% of people, 99% of the time won't need the locking rear diff.
Sun Aug 12 2018 11:23pm |
